in line fuel filter
  • Kwaker2000
  • Kwaker2000's Avatar Topic Author
in line fuel filter
06 Mar 2015 14:30
#663647
hi guys im after an inline fuel filter they all seem to be plastic ,the problem is this ethanol doesint like plastic, what do you suggest i use
dave
  • Tyrell Corp
  • Tyrell Corp's Avatar
Re: in line fuel filter
06 Mar 2015 15:48
#663651
There are some fancy custom glass and chrome with a re-cleanable filter. The only problem being the strainer is bit coarse, similar to the strainer in the tank on the top of the fuel tap. Paper filters give better filtration but but can sometimes create their own problems in gravity feed non-efi applications., unless you get one specifically for bikes or garden machinery.
The following user(s) said Thank You: Kwaker2000
06 Mar 2015 15:51 - 06 Mar 2015 15:52
#663653
Here's what I use - no plastic. It not only filters great it also fits great - Golan Super-Mini (see 70-312G 5/16 Barbed Fittings in link) on mine. Take a look at the link below. It shows not just the filter but also the 90 degree elbow I use to prevent kinks and make a tidy fit between carbs and tank, clamps, and fuel line. Ed
www.kzrider.com/forum/3-carburetor/59406...ne-and-filter#633243
Last edit: 06 Mar 2015 15:52 by 650ed.
  • Kwaker2000
07 Mar 2015 00:40
#663666
what a great bunch of guys thanks for the help :)
dave
  • SWest
  • SWest's Avatar
  • 10 22 2014
07 Mar 2015 06:58
#663678
I've been using bullet plastic clear filters for years. I bought two from Z1E but they were too big. I broke one and bought a smaller one at a dirt bike shop for $4.99. Most shops have them at this price. No problems with them.
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
08 Mar 2015 08:33 - 08 Mar 2015 08:34
#663747
Here is what happens when ethanol meets a crappy filter. These were ony a few months old...
[IMG
I'm going with what 650Ed recomended.
It should also be said I have used Visu Vu filters for years without any problems. These were cheap chinese knock-offs.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
Last edit: 08 Mar 2015 08:34 by ThatGPzGuy.
  • MFolks
  • MFolks's Avatar
08 Mar 2015 08:46
#663748
And using the glass bodied ones, is even a worse solution. They break from vibration, and now all the gas needs is an ignition source. You'd think by now, the makers of the plastic fuel filters, would've found a material that resists Ethanol.
  • martin_csr
  • martin_csr's Avatar
08 Mar 2015 08:57
#663749
Aluminum-bodied fuel filters are available. Russell is one brand.
Some have brass elements which can be cleaned or replaced.
  • Tyrell Corp
13 Mar 2015 13:15 - 13 Mar 2015 13:18
#664344
Not sure about vibration damage, the filters are pretty well rubber mounted it could be said.
Also the vacuum fuel tap shuts off when engine is stopped,
I had a glass in-line for years no probs, just I though the gauze 'filtration' a little too coarse, on the chrome and glass fancy custom thingy i had.
Last edit: 13 Mar 2015 13:18 by Tyrell Corp.
  • SWest
  • SWest's Avatar
  • 10 22 2014
13 Mar 2015 19:11
#664364
ThatGPzGuy wrote: Here is what happens when ethanol meets a crappy filter. These were ony a few months old...
[IMG
That's the problem. Ethinol is a scam by the Fed and big Farma. Nothing will happen if people just bitch and not vote.
I'm done now.
  • bluej58
  • bluej58's Avatar
14 Mar 2015 03:35
#664372
I figure if the particles are small enough to get through the petcock screen then they will be small enough to pass through the carbs with out any problems :huh:
78 KZ1000 A2A
  • SWest
  • SWest's Avatar
  • 10 22 2014
14 Mar 2015 05:12
#664377
The sediments can collect in the bottom of the bowl, then be sucked up under hard acceleration. It's best to have them.
