4mm thread just about had it.
  • Zephyrrider
  • Zephyrrider's Avatar Topic Author
25 Feb 2015 14:54
#662765
What would you recommend to rebuild a 4 mm thread for 1 x vacumn cap - only have a few mm length to play with, Thanks,
Mick.
Mick
1994 ZR750 Zephyr C4.
  • martin_csr
  • martin_csr's Avatar
Re: 4mm thread just about had it.
25 Feb 2015 15:47
#662767
Maybe post a photo of what's messed up.
The following user(s) said Thank You: PLUMMEN, BlackZ1R
  • Zephyrrider
26 Feb 2015 14:21 - 26 Feb 2015 14:45
#662819
Attachment WornThread.jpg not found
No 3 carb - choke bracket mounting point. Just needs something to give it a little bite again.There is some thread but not quite enough. These are a spare set so no urgency, Thanks, Mick.
Mick
Last edit: 26 Feb 2015 14:45 by Zephyrrider.
  • moneypit
  • moneypit's Avatar
26 Feb 2015 14:29
#662820
Maybe try a sae/not metric. I had to do that on my 29s for a float bowl Slightly bigger than the metric size. Just a thought.
2-76 kz900
St Paul MN
  • Zephyrrider
26 Feb 2015 14:47 - 26 Feb 2015 14:48
#662821
Moneypit Thanks for that mate but i will try and build it up first - like to keep em all the same size,
Mick.
Mick
Last edit: 26 Feb 2015 14:48 by Zephyrrider.
  • 80B4
  • 80B4's Avatar
26 Feb 2015 15:25
#662824
I've used a helicoil for repairing carb. McMaster.com and MSC have the kits.
1980B4 1000
1978 Z1R
1978 B3 750
26 Feb 2015 16:15
#662827
If not helicoil you may want to have a timesert installed. You may be able to find a local machinist who can do it rather than buying a rather expensive kit for just 1 hole. Here's a link to the timesert site. Ed
www.timesert.com/html/mtrcsert.html
  • Zephyrrider
26 Feb 2015 20:27
#662854
Thanks for your advice - will look for a local i reckon. Couldn't see any prices for singles or kits of the timeserts - will check out the website anyway. It is very rare for me to need to do this sort of job- always very careful with that soft stuff. Mick.
Mick
  • SWest
  • SWest's Avatar
  • 10 22 2014
26 Feb 2015 21:32
#662859
I just bought the coils and tap. I used a small screw driver to install them. Here we have fastinal, do you have a bolt vendor there?
  • MDZ1rider
  • MDZ1rider's Avatar
27 Feb 2015 10:49
#662885
For a low torque screw like that, I've covered the screw threads with oil and then a thin layer of JB weld. Install the screw as normal. Allow the JB weld to set and back out the screw. The JB weld bonds to the clean surface of the carb, but not the oil covered threads of the screw. Instant new threads. This isn't a solution for every stripped hole, but does work in the right situations.
The following user(s) said Thank You: Zephyrrider
  • Zephyrrider
27 Feb 2015 14:43
#662912
Thanks MDZ1rider - $15 for JBWeld at local store - will give it a shot - sounds like JB would be great for lots of jobs.
ED and Steve we have a reseller for timesert here - a M4 x 0.7 kit of 5 inserts would be $55 so not too bad.
Will give the JB a go first,
Mick.
Mick
  • 80B4
  • 80B4's Avatar
27 Feb 2015 16:24
#662918
I just took a look on google.com and a 4mm helicoil kit is less than $36 delivered. It is a cool tool and you will have it forever.
1980B4 1000
1978 Z1R
1978 B3 750
