28mm bad rap ?
- KZPETE33
- 76 900 Constant thorn in my side....love it.
28mm bad rap ?
17 Feb 2015 18:51
I haven't heard anything good about 28mm carbs, say 29mm smoothbores are super hard to find, need fixed when you do find them, CR Specials are new, but still need tuned on...would a fella use 2nd gen 28's or 26"s ?
- PLUMMEN
Re: 28mm bad rap ?
17 Feb 2015 19:15
ing wrong with 28s.
The following user(s) said Thank You: KZPETE33
- DFIGPZ
Re: 28mm bad rap ?
17 Feb 2015 19:51
nothing wrong with 28s I use them all the time saves money over 29s never had an issue and a lot less money
1984 750 Turbo
Re: 28mm bad rap ?
17 Feb 2015 20:03
I ran my 28's for 25 years. The only problem was the outside linkage. There's a little tab that connects 1/2 3/4 together. It can get weak and the linkage sticky. I only changed them when I got my 33's. Not a lot of difference. At least not earth shaking.
I still have my 28's.
- gd4now
- Denco where did you go?
Re: 28mm bad rap ?
18 Feb 2015 00:18
Which 28s are you asking about - vm28sc or vm28ss?
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Re: 28mm bad rap ?
18 Feb 2015 05:52
Nice little bike. Mikie had one. He abused it then traded it for a bag. I'd like to have bought it from him but I was a single parent at the time. I should have given him $200 for it, fixed it and saved to overhaul Bossie.
Shoulda, woulda, coulda.
- KZPETE33
Re: 28mm bad rap ?
18 Feb 2015 18:58
Thanks guys, vm28ss I believe, looks like a good tune-up will fix'em !
Re: 28mm bad rap ?
19 Feb 2015 06:44
Do the carbs in question have covers with 2 screws or covers with 3 screws?
- KZPETE33
Re: 28mm bad rap ?
19 Feb 2015 16:19
Have 2 screw caps with the angled drain screw on bowls.
Re: 28mm bad rap ?
19 Feb 2015 16:33 - 19 Feb 2015 16:34KZPETE33 wrote: Have 2 screw caps with the angled drain screw on bowls.
For some pics and info about the Z1-A & Z1-B Mikuni 28mm carbs,
click here > www.z1enterprises.com/Z1CarbGuide.aspx
Last edit: 19 Feb 2015 16:34 by Patton.
- BlackZ1R
- Kawasaki in my blood
Re: 28mm bad rap ?
20 Feb 2015 19:50
The later 28s held sync better than the early ones. I have a really nice set of 29s that are ready to bolt on and ride, if you are interested. No stripped threads. Ready to ride.
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
- KZPETE33
