28mm bad rap ?
  • BlackZ1R
  • BlackZ1R's Avatar
  • Kawasaki in my blood
Re: 28mm bad rap ?
22 Feb 2015 21:30
#662443
KZPETE33 wrote: Kinda money on the 29's ?
Shoot me a PM i f you're interested. We can discuss it.
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
  • KZPETE33
  • KZPETE33's Avatar Topic Author
  • 76 900 Constant thorn in my side....love it.
Re: 28mm bad rap ?
08 Mar 2015 14:42
#663759
Ok, dumb question time. Using the 28mm carbs, bike has always been rich, Dyna S ignition and coils. With the bowls off, slides ran all the way down, idle backed off, should you be able to blow air through main jet ?
Re: 28mm bad rap ?
08 Mar 2015 14:58 - 08 Mar 2015 19:23
#663760
KZPETE33 wrote: Ok, dumb question time. Using the 28mm carbs, bike has always been rich, Dyna S ignition and coils. With the bowls off, slides ran all the way down, idle backed off, should you be able to blow air through main jet ?
Excessive richness may be caused by either (for whatever reason) -- or any combination of -- insufficient combustion, weak spark, and/or too rich fuel mixture.
Not surprising that air could be blown through the main jet with jet needle fully down inside the needle jet, because the fit between needle and jet isn't an air-tight fit.
Good Fortune! :)
Last edit: 08 Mar 2015 19:23 by Patton.
The following user(s) said Thank You: KZPETE33
  • KZPETE33
Re: 28mm bad rap ?
08 Mar 2015 15:37
#663766
Motor is a MTC 1015, Andrews 2X cams, head ported, cams degreed @108. Currently has 17.5 pilots and 107.5 mains, needle on second notch from the top, should be lean as hell. I'm going to check float height next....(clear tube test)
