Removing carb assembly Z500 B -81
  • noratx
  • noratx's Avatar Topic Author
15 Feb 2015 11:31
#661682
Hi!
I have recently aquired a Kawasaki Z500 B -81, that will need a carb cleaning.
Now, according the haynes manual I got, it says I need to disconnect the carb slider arms, pulleys etc from the carb shaft.
I am starting to question this though.
I would prefer, if possible, to simply get the whole assembly out BEFORE removing each individual carburettor.
Is this possible? And if so, how?
Also, the screw on the right hand pulley seems to be somewhat damaged.
Seems like the previous owner has tried to unscrew it, but instead damaged the head.
Is there anyone of you who know the measurements of this screw, so that I can replace it when I manage to remove it. (This is one of the reasons I'd prefer to get the whole assembly out instead of each individual carburettor. Would make it so much easier to try removing that screw.)
Thanks for now
/Rickard
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Removing carb assembly Z500 B -81
15 Feb 2015 15:54
#661705
Your first mistake is the manual. The carbs come out as a set. Only things need to be taken off are the throttle cables. If you're going to clean them, do it as a set. Don't take them apart. Pics are a must for help here.
Oh yeah, a factory service manual too.
  • noratx
15 Feb 2015 16:10 - 15 Feb 2015 16:12
#661706
A factory service manual is not easy to aquire, I have search high and low, both for pdf and paper ones. (You don't happen to have one? *wink*)
The haynes manual is what I have found so far, and a factory service manual for GPZ 400, 500, 550 and Z400 and 500 F.
The one I got is a Z500 B3.
As far as I have seen, these models are the same engine and carb assembly.
Some with slide carbs and some with constant depressed (?) carbs. (Mine is Teikei slides).
I'm not allowed to attach the PDF manual here, so in case it could be usefull in order to get the help needed, here's a public dropbox link.
dl.dropboxusercontent.com/u/94318707/448...vice-Manual-Supl.pdf
I will go take some pics tomorrow, question is, are there any angels I should be extra aware of to take pictures from?
The help is much needed, just want to make sure I get good enough pics. :)
I am grateful for all help I can get. :)
Last edit: 15 Feb 2015 16:12 by noratx.
  • mopguy
  • mopguy's Avatar
15 Feb 2015 16:16
#661707
Click on the ARTICLES icon at the top, next click on TECHNICAL TIPS, now read Carburetor Cleaning 101 & 102, hope this helps.
  • SWest
  • SWest's Avatar
  • 10 22 2014
15 Feb 2015 17:11
#661712
Just a couple pics of the carbs at first. We all like to see the bikes so a few of as well can help get better feed back. Some bikes are worth putting money into, some aren't.
15 Feb 2015 19:25
#661728
See following links courtesy of KZr Member loudhvx
General
home.comcast.net/~loudgpz/GPZweb/index.html#home
Service manuals
home.comcast.net/~loudgpz/GPZweb/Mnls/Mnls.html
Good Fortune! :)
  • noratx
18 Feb 2015 10:32
#661976
Mopguy Thank you! :)
Patton: Wonderful, thanks! :)
Swest: I cought a pretty bad cold the other day and havn't felt good enough to go to the garage. WIll go and get some picks when I get better :)
In the mean time, I do have a few other pics, none that are showing much of the engine/carbs though :)
  • martin_csr
  • martin_csr's Avatar
  • SWest
  • SWest's Avatar
  • 10 22 2014
18 Feb 2015 17:01
#662000
You gave pods on it. Taking off the carbs is easy.
  • loudhvx
  • loudhvx's Avatar
18 Feb 2015 17:26 - 18 Feb 2015 17:29
#662003
As others have said, there is no routine reason to separate the carbs. Doing so often causes minor damage to hardware, shafts, and dust seals (that you can't easily get anymore). It may even cause the fuel pipes to start leaking.
Most things in the float bowls can be removed and cleaned, as well as the slides, and air screw passages. The throttle shaft should be left in place, along with the carb bodies. The choke shaft is not too hard to remove if you clean it first, and remove any corrosion before pulling it, but there still isn't a lot of reason to do that.
There are a few mods you can do to the choke system to make it more stable. The links are at the bottom of the TK22 carb page. A link to that is in my signature.
I suggest you download all of the manuals (in my signature or in Patton's link above). That way you can compare differences and maybe catch any errors you might find in one manual.
Last edit: 18 Feb 2015 17:29 by loudhvx.
