carb pilot screw settings csr1000 m1
- Kwaker2000
01 Feb 2015 13:19 - 01 Feb 2015 13:21
hi guys great forum you have here , can you tell me what my pilot screw settings should be ,i have standerd air box with k n filter in, i have ajusted carbs to 1 3/4 turns out as was runing lean , i have also removed the smog stuff as im in england so dont need it ,pluged hole in air box and the pipe that goes to 2 carb vac intakes ,i have left on and pluged end of t bar,i have also got a pipe runing across both reed valves, i have cleaned carbs out and oiled advancer
Last edit: 01 Feb 2015 13:21 by Kwaker2000.
Re: carb pilot screw settings csr1000 m1
01 Feb 2015 19:52
Check your plugs. They should tell if you are too lean or not.
The following user(s) said Thank You: Kwaker2000
- davido
01 Feb 2015 23:24
Are you talking about the idle mixture screw??
If so,the Clymer book says 1 and 1/4 turns out.If not,I dont know.
Good luck with it.
Good luck with it.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- Kwaker2000
02 Feb 2015 11:19
it doesint run right 1 1/4 turns out, i have k&n filter in air box so i have had to compansate for it, the plugs look a brown tan so i think i have it about right at 1 3/4 out thanks for advice guys ,took her for a short spin pulls like a train
love these old kwaks
02 Feb 2015 13:41
That's the color your looking for.
