- Thank you received: 13
It Started !
- kzdcw
- 77' KZ1000A
Question, the bike when when idling doesn't seem to respond well to quick throttle inputs maybe like it's starving for fuel and returns back to idle slowly?
Any Recommendations you Tech Guys may have?
Other than that, I'm tickled to death it's running since 1988 !
77' KZ1000A
- Thank you received: 2756
- kzdcw
- 77' KZ1000A
Which direction would I turn to the idle mixture screw to combat the symptoms I described above?
77' KZ1000A
Have you adjusted the floats?
- Thank you received: 2098
kzdcw wrote: ...F77' KZ1000A... stock VM26 carbs...backed out the Fuel Mixture Screws 1 1/2 Turns...when idling doesn't seem to respond well to quick throttle inputs maybe like it's starving for fuel and returns back to idle slowly?....
Turning the pilot mixture screw out counterclockwise enrichens the pilot circuit.
Conversely, turning the pilot mixture screw in clockwise leans the pilot circuit.
- Tripleted
- Thank you received: 3
- Tripleted
- kzdcw
- 77' KZ1000A
I thought when you try to open the throttle slightly and slowly and it take a brief moment to respond then returns to idle slowly when letting off the throttle would mean that the idle circuit or Pilot circuit is LEAN ?
If that's the case I'm assuming you would want to Enrichen the Fuel Mixture but thought would be done by turning ( IN ) the Mixture Screw?
I already set the Mixture Screw at 1 1/2 turns out as a starting point.
77' KZ1000A
- spdygon
- Thank you received: 117
My 77kz1000 carbs use 17.5 and 120mains
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
- kzdcw
- 77' KZ1000A
I know the bike would probably run much better with new Plug wires and Coils as well as New points. But for right now using the Old ones. I did however test them per FSM and adjusted accordingly.
77' KZ1000A
