Need some expert tuning advice...
- Gdailey2112
- 82 KZ1100D1
Re: Need some expert tuning advice...
09 Aug 2022 02:58so are the vents you speak of between 1/2 and 3/4, are they "T's"?If not already done, would assure that the two carb vent hoses are serviceable and that both of them exit to open air.
The vents are needed to allow supply of incoming fuel into the float bowls.
1982 KZ1100D1
- zed1015
09 Aug 2022 03:42This is an old thread but the tees between the carbs are fuel inlets.
Vents are the brass tubes on carbs 2 and 4.
The following user(s) said Thank You: Gdailey2112
