Bike starts and runs only while choke is on...
- Harley Killer
21 Dec 2014 12:58
I have a 1979 KZ 1000.... wouldnt start and run..... I adjusted the air flow intake... Bike starts and runs good only with the choke engaged.... when you turn the choke off it backfires through the carbs and dies.... any advice on what I should do next?
- !Seymore
- Ride on...
Re: Bike starts and runs only while choke is on...
21 Dec 2014 14:32
Sounds like a REALLY GOOD carb cleaning is in order...
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
21 Dec 2014 16:02
How are the carb boots to the head? How long has this been happening? Has it sit for a long time?
Harley killer, I like that. They sneer at me until I fire Bossie up, that's when they get mad and look the other way. I've had woman treat me like that and I walk the other way.
- baldy110
24 Dec 2014 08:55
Running only with choke is a classic symptom of clogged and dirty carburetors. Your carbs need to be cleaned, pay particular attention to the idle circuit, pilot jets and passageways. Make sure all the jets and carb body passageways are clean and clear.
24 Dec 2014 09:20 - 24 Dec 2014 09:21
Do you have the stock air box and filter hooked up to the carbs and are the vacuum caps on tight? Ed
Last edit: 24 Dec 2014 09:21 by 650ed.
