kz650 stalling after warm up
- gcphoto
I've got a video to help hear and see what I'm talking about:
'78 KZ650 SR
___________
Wear a helmet, pants are optional.
- gcphoto
'78 KZ650 SR
___________
- Grnole
- Thank you received: 8
Without being in front of your bike. I would say you likely have a fuel issue either your drain screws are stripped or your fuel is leaking from the seal due to a bad float or tang adjustment - clear tube method will allow you to test your foats... that could be causing the drip ...
I have chased down a bunch of little things personally with my bike. Dirty carbs, crappy petcock lack of fuel filter, and faulty ignition system.
Hard to test because you need to test the coils when hot, and at times, it could even give you a false reading.
Are you still running points with mechanical advance? Were you able to confirm all the cyl are firing? What drove me to thinking mine was related to coils, was that 2 of my four cyl were cold when it would run rough... and those two were controlled by the same coil.
--- take a look at this tread I posted --- www.kzrider.com/forum/2-engine/595858-ru...-after-bike-gets-hot
1980 KZ1000 LTD -B4
1984 Yamaha FJ1100
1972 Honda CL350 (sold)
- Thank you received: 2098
Patton wrote:
Grnole wrote: ... the bike could no longer hold an idle, especially after it is warmed up....
Insufficient valve clearances can result in these symptoms.
Cool engine starts and runs okay until it warms up and then runs less okay and won't idle.
- !Seymore
- Ride on...
- Thank you received: 69
But Patton has a point. Check your valve clearances.
C.
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
- Thank you received: 2829
- bountyhunter
- Thank you received: 337
The other possibilities have been listed: valve clearance is one.
But fuel dripping off the carb makes me think one or more of the carbs needs it's float level adjusted using clear tube method. It's also possible there's a problem with the seal and the float valve so you have some continual flooding or overflow.
- gcphoto
'78 KZ650 SR
___________
- gcphoto
'78 KZ650 SR
___________
- gcphoto
'78 KZ650 SR
___________
- murquiza
gcphoto wrote: Just spent 20 minutes looking around for a clear tube tool and this is all I could find on z1.. www.z1enterprises.com/ItemDetails.aspx?i...asaki&item=57001-208 . It's the same thing depicted in my service manual but seems pretty expensive for what it is at $70. Someone mentioned ebay but I can't find anything. I've never done it before but read the instructions. Alternately I can just get a basic piece of clear tubing, unscrew the drain screw and pop on the clear tube?
About $8
Bikes:
1979 KZ650-D2 SR
2006 Vulcan 2000-A
2006 ZX10R
2008 Versys KLE650
www.z1enterprises.com/ItemDetails.aspx?i...uzuki&item=ZSM01-208
