Petcock leaking after rebuild..
- CharlieLamberti
..to rebuild my petcock just now, and it drips out of the fuel outlet.
Wondering if anyone has experience with these kits being junk. I did polish the o-ring seat with steel wool before re-assembling, and nothing looked out of the ordinary.
Any petcock rebuild tips, tricks, advice.. anything really is appreciated.
Keep on keepin' on.
1981 kz750ltd
- zero10
- Thank you received: 6
Did that kit include the petcock to tank o-ring?
- azman857
- Thank you received: 112
- CharlieLamberti
The kit came with all of the rubber parts for the petcock, the tank o-ring is pictured there and comes as just an o-ring that you have to shape to the groove in the petcock. I like that it's made in Japan, and seems to be of a high quality.
I have the tank off and set up on the lip of a dry pan, will update tomorrow.
Keep on keepin' on.
1981 kz750ltd
- CharlieLamberti
Keep on keepin' on.
1981 kz750ltd
- JR
- Thank you received: 449
I actually like the vacuum petcock. I would put manual petcocks are in the same league as old style points ignitions
- Thank you received: 2829
JR wrote: It's years since I had to do anything with my petcock but I seem to remember that I had to take the spring and stretch it a bit so that gas stopped when the vacuum was off. That was probably 10 years ago and it has been fine since.
Me too! I have points ignition and a manual petcock - I've had no problems with either one. Ed
- CharlieLamberti
All of this stuff works the way it's supposed too when well maintained. If my bike had points and a manual petcock when I got it; I'd keep it that way.
Keep on keepin' on.
1981 kz750ltd
- JR
Ha ha
Good one Ed
Touche :laugh:
- nickleo373
- Thank you received: 33
1981 KZ550C LTD
"If you ain't first, you're last"
- zero10
nickleo373 wrote: Try pulling the spring apart and reinstalling it. There is also a backing plate that should be bent that sits next to the on off res lever. If you slightly bend the plate back into its original position it should stop the leak.
Is there a diagram of this somewhere?... if it needs to be bent and I've never had it apart before how will I know what it's original position is?
- CharlieLamberti
Keep on keepin' on.
1981 kz750ltd
