Petcock leaking after rebuild..
- nickleo373
Re: Petcock leaking after rebuild..
10 Oct 2014 10:13 - 10 Oct 2014 10:19
The circled part in this diagram is the part I was referring to. The part is already bent from the factory. It just seems to straighten out over time and needs to be bent slightly more in the same direction the factory did it.
1981 KZ550C LTD
"If you ain't first, you're last"
Last edit: 10 Oct 2014 10:19 by nickleo373.
- soldierbp
29 Oct 2014 13:46
Hey nickleo373, is that washer / o-ring with part # 92055A rubber or metal?
29 Oct 2014 13:58
Rubber. $1.96 at Partzilla.com.
www.partzilla.com/search/?q=+92055-1027&x=7&y=11
Attachment 00003b_2014-10-29.jpg not found
Attachment 00003a_2014-10-29.jpg not found
The following user(s) said Thank You: soldierbp
