Carbs get fuel *sometimes*
21 May 2014 21:18 #633386 by freakinbike
Carbs get fuel *sometimes* was created by freakinbike
I'm having an issue where my carbs aren't getting fuel constantly while running. They'll get fuel to be able to run for a minute, then it dies. Sometimes it won't start at all because the carbs are dry.
If I set the fuel tap to PRI, then the bike will chug, but only at full throttle. As soon as I let up on the throttle, it dies.
Could this be a float issue? If so, which way do they need to be tuned? I set them to the stock height of 18mm the last time I rebuilt them (two weeks ago).
1982 GPz750 w/ Mikuni BS34s
1982 GPZ750, stock (for now..)
1973 VW Bus
Can life really get much better?
21 May 2014 21:42 - 21 May 2014 21:43 #633388 by bountyhunter
Replied by bountyhunter on topic Carbs get fuel *sometimes*
Could be a bad petcock or a blocked air vent in the gas cap.
Could be a float/needle if they are sticking in the up (closed) position.
Last edit: 21 May 2014 21:43 by bountyhunter.
22 May 2014 03:11 #633398 by ZERO
Replied by ZERO on topic Carbs get fuel *sometimes*
+1 petcock.
Only Kawasakis have a soul 1977 Kawi KZ1000 special 2000 Kawi ZRX1100
22 May 2014 16:35 #633526 by freakinbike
Replied by freakinbike on topic Carbs get fuel *sometimes*
Is there a way to check the petcock?
1973 VW Bus
22 May 2014 21:11 - 22 May 2014 21:18 #633577 by loudhvx
Replied by loudhvx on topic Carbs get fuel *sometimes*
Well, you can actually activate it by sucking on the vacuum line, but don't let anybody see you. :whistle:
The less embarrassing option is to go to any pharmacy and get a large, plastic syringe. Put that into the vacuum line and that should activate the fuel flow easily.
This is the one I use on manometers, but it also works for petcocks.
Are you using a car fuel filter? The see through ones with paper elements often will stop flowing. They are meant for fuel pumps. Gravity doesn't apply enough pressure.
I've posted this before, but I'll post it again in case others might not have seen it.
Last edit: 22 May 2014 21:18 by loudhvx.
22 May 2014 21:20 - 22 May 2014 21:28 #633578 by pscycle
Replied by pscycle on topic Carbs get fuel *sometimes*
Should be able to unbolt and or unscrew check to be sure the screen for the petcock is not plugged up clean the petcock ports and inspect any rubber for damage. Sometimes plugged vent holes will cause problems Im not sure how your carbs vent but just a thought.
pscycle927
Last edit: 22 May 2014 21:28 by pscycle.
23 May 2014 06:42 #633618 by freakinbike
loudhvx wrote: Well, you can actually activate it by sucking on the vacuum line, but don't let anybody see you. :whistle:
I have been using a fuel filter, but thought it could be a culprit so it's currently not attached. After taking it off, fuel flowed slightly, but not nearly enough. Is there a filter that I can use?
I've taken apart and cleaned the petcock and there wasn't much gunk in there. Nothing changed when I reinstalled it.
1973 VW Bus
  • slayer61
  • KZR FLAG RELAY CARRIER #62
23 May 2014 08:50 #633640 by slayer61
Replied by slayer61 on topic Carbs get fuel *sometimes*
I went through this with a bank of Keihin CR Specials a few years ago. Tried everything under the sun to get fuel to flow to them. All the meanwhile my wife was saying "is the fuel line clear?" After a complete weekend of dicking around, and listening to her ask the same question over and over, I decided to appease her and blow out the fuel line. Like magic, some lump of crap blew out and problem solved!
23 May 2014 11:07 #633650 by loudhvx
You can use the metal screen filters available at Z1 Enterprises. There are also ones that are in an aluminum body with a cleanable internal scintered brass/bronze filter.
25 May 2014 11:29 #633934 by freakinbike
So I tried sucking on the vacuum line attached to the petcock, and a little bit of fuel flowed, but stopped after a second. Is there maybe a diaphragm that's getting stuck when vacuum is applied?
I also tried this with the tap set to PRI and had the same results; just a little shot of fuel then nothing.
1973 VW Bus
25 May 2014 12:01 #633937 by azman857
Replied by azman857 on topic Carbs get fuel *sometimes*
Sounds like the petcock needs rebuilding. Passages clogging and vacuum diaphram leaking perhaps. Clean and seal the tank too so it doesn't clog up the petcock again as well as make rust holes .
25 May 2014 13:03 #633943 by loudhvx
Yup, should have flowed continuously under both conditions. The normal position takes gas from one pipe, and the prime position takes gas from the reserve pipe. So if there's any gas, it should have flowed.
So the petcock will have to be inspected.
Clean the tank, but only use a tank liner if you absolutely, absolutely have to. It's mess if the liner goes bad.
