Why is one of my carbs keep overflowing with gas?
- Waynecarpenter
- mopguy
- Thank you received: 168
- Waynecarpenter
- Waynecarpenter
- slayer61
- KZR FLAG RELAY CARRIER #62
like mopguy already said... "Could be the float or needle is stuck, try tapping the float bowls and see if vibration loosens it up, if it still overflows, then you need to re adjust the float using the clear tube test method. " Also look at replacing the faulty float valve needle and seat. Consider this... If one is leaking now, will the others be long behind?Waynecarpenter wrote: Also pulled the tank. I have a Manuel petcock. On flows gas very well. Reserve flows very well. When it's on the off position it still slightly flows. Could this be the issue? If so why does only one carb overflow?
A petcock that leaks isn't good. in the "OFF" position it should be "OFF".
- 331lxstang
- Thank you received: 2
1977 Santee hardtail, 1075 Andrews 3x cams, old school
1978 KZ 1000 under restoration to original
- Waynecarpenter
Attachment ImageUploadedByTapatalk1400434021.970866.jpg not found
Next as far a the needle being stuck. Just to confirm the needle you are talking about it the needle in the plunger thing on the top portion of the carb right.
Attachment ImageUploadedByTapatalk1400434221.255358.jpg not found
If so the plunger and needle move very easily and seem to be unstuck.
- Waynecarpenter
Attachment ImageUploadedByTapatalk1400434426.490792.jpg not found
This plug and o ring seems to have seen better days. It doesn't seem to actually seal itself in the hole. Could almost just fall out its that loose.
Attachment ImageUploadedByTapatalk1400434606.435727.jpg not found
My thought is since it doesn't seal gas is going through it and leaking out.
- Waynecarpenter
Attachment ImageUploadedByTapatalk1400435051.290967.jpg not found
Attachment ImageUploadedByTapatalk1400435130.095792.jpg not found
The plunger in the float needle seems free. And the float needle goes in and out of the seat without problem.
- Waynecarpenter
- nickleo373
- Thank you received: 33
1981 KZ550C LTD
"If you ain't first, you're last"
- Waynecarpenter
