Why is one of my carbs keep overflowing with gas?
- Waynecarpenter
16 May 2014 10:05
I have a set of k&n pod filters on my carbs. On one of my carbs it seems to be overflowing and dripping out of the filter. Any ideas?
- mopguy
Re: Why is one of my carbs keep overflowing with gas?
16 May 2014 10:28
Could be the float or needle is stuck, try tapping the float bowls and see if vibration loosens it up, if it still overflows, then you need to re adjust the float using the clear tube test method.
- Waynecarpenter
16 May 2014 10:36
I remember seeing a post about that. I'll search but in the mean time does anyone have a link to it?
- Waynecarpenter
16 May 2014 12:28
Also pulled the tank. I have a Manuel petcock. On flows gas very well. Reserve flows very well. When it's on the off position it still slightly flows. Could this be the issue? If so why does only one carb overflow?
- slayer61
- KZR FLAG RELAY CARRIER #62
16 May 2014 13:10like mopguy already said... "Could be the float or needle is stuck, try tapping the float bowls and see if vibration loosens it up, if it still overflows, then you need to re adjust the float using the clear tube test method. " Also look at replacing the faulty float valve needle and seat. Consider this... If one is leaking now, will the others be long behind?Waynecarpenter wrote: Also pulled the tank. I have a Manuel petcock. On flows gas very well. Reserve flows very well. When it's on the off position it still slightly flows. Could this be the issue? If so why does only one carb overflow?
A petcock that leaks isn't good. in the "OFF" position it should be "OFF".
- 331lxstang
16 May 2014 15:47
Check float level, check for leaking needle and seat, and from personal experience that almost drove me bonkers check that overflow tube in the bowl itself for a crack or hairline split. Mine had a hairline crack in it and no matter where you set the float fuel kept running out the overflow. I think its a rarity, but I'll never rebuild a set of carbs again without checking the overflow tubes.
1977 Santee hardtail, 1075 Andrews 3x cams, old school
1978 KZ 1000 under restoration to original
- Waynecarpenter
18 May 2014 10:31
I'll look into the petcock a little later. The float seems to be very free, unstuck and bouncy. See pic to confirm I'm looking at the correct part.
Next as far a the needle being stuck. Just to confirm the needle you are talking about it the needle in the plunger thing on the top portion of the carb right.
If so the plunger and needle move very easily and seem to be unstuck.
Attachment ImageUploadedByTapatalk1400434021.970866.jpg not found
Attachment ImageUploadedByTapatalk1400434221.255358.jpg not found
- Waynecarpenter
18 May 2014 10:39
Btw gas seems to be coming from here.
This plug and o ring seems to have seen better days. It doesn't seem to actually seal itself in the hole. Could almost just fall out its that loose.
My thought is since it doesn't seal gas is going through it and leaking out.
Attachment ImageUploadedByTapatalk1400434426.490792.jpg not found
Attachment ImageUploadedByTapatalk1400434606.435727.jpg not found
- Waynecarpenter
18 May 2014 10:47
Does my float valve needle look ok? How do I know if it's bad. Also anything look bad with the seat based on just a pic?
The plunger in the float needle seems free. And the float needle goes in and out of the seat without problem.
Attachment ImageUploadedByTapatalk1400435051.290967.jpg not found
Attachment ImageUploadedByTapatalk1400435130.095792.jpg not found
- Waynecarpenter
- nickleo373
19 May 2014 09:57
Push the spring on the float pin. If you see dirt come flying out of it or it doesn't return to it's original position quickly, you should replace the seats and needles.
1981 KZ550C LTD
"If you ain't first, you're last"
- Waynecarpenter
19 May 2014 17:59
It returns just fine. And no dirt comes out. Gonna check the fuel level. Gotta get some clear hose.
