Throttle hesitation-Floats? Idol Jets?
- pnedac
78 KZ650 B
- nickleo373
- Thank you received: 33
1981 KZ550C LTD
"If you ain't first, you're last"
- Thank you received: 2829
nickleo373 wrote: When pods are involved, the engine bogging at all is usually associated with improper jetting
Yup. Not at all unusual. If the engine is stock you will find it challenging to make it run as well using pods as it did with the airbox throughout the rpm range. I never have seen anyone post the perfect jetting combination despite many thousands of postings on the subject on this site. Ed
- baldy110
- Thank you received: 512
My jetting on the VM24 carbs are
Dynojet main #118
Pilot jet is 17.5
Dynojet needle with clip in the 2nd slot from top.
Pilot air screw I move around depending on the season, 2.5 turns out in the summer and 2.00 turns out in the winter.
baldy110 wrote: My 78 KZ650 is jetted perfect and it's running pod filters and a 4 into 1 pipe. In fact is runs better than it did when it was stock and I bought in new in 1978. Even when it was new It had a very slight flat spot right off idle that I could not get rid of. I tried all the tricks of the day, installing a KZ900 advance unit, fancy spark plugs, electronic ignition, ect. I finally cured by getting a jet kit, installing pod filters, RC pipe and spending a few weekends dialing the carbs in. It was a pain the ass but worth it. The thing runs great to this day, very smooth from idle to the redline with no weird hesitations or bogs.
That's good to know. Hopefully pnedac will be able to replicate your success using your jetting specs. Ed
- pnedac
Pnedac
78 KZ650 B
- pnedac
Dynojet main #118
Pilot jet is 17.5
This is the only one I changed as I had everything else the same already. Mine had the 11.5 jet.
So it still is bogging down just a bit and it smells a little rich. Can I accomplish the leaning out by manipulating the pilot screws ever so slightly? I believe I can, but I would love to get a little confirmation that I am headed in the right direction before I go tinkering too much more.
Thank you again! I attached a picture of the bike for fun. I will say, it is a great bike!
Attachment 2014-04-0418.16.42.jpg not found
Pnedac
78 KZ650 B
- gd4now
- Denco where did you go?
- Thank you received: 443
In general I think a good starting point for the vm24ss carbs on a KZ650 when running pods and a 4 into 1 exhaust is as follows
110 main
17.5 pilot
On the 5DL3 jet needles, clip to the 3rd position and the others get clipped to the 4th slot.
Again want to stress that this a good starting point and not necessarily where you will end up.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- bountyhunter
- Thank you received: 337
Maybe, but the slide is also lifting off the base just as you start opening the throttle and needle position can make a big difference there. You might try going one click leaner on needle position.pnedac wrote: Okay so I put the settings to be the same as baldy110:
Dynojet main #118
Pilot jet is 17.5
- pnedac
Attachment 2014-05-0716.18.14.jpg not found
NOTE: The petcock was changed from vacuum to gravity so I am not sure that these should have been plugged, but perhaps the one port SHOULD have been. The one little one is for the vacuum petcock and should be. Can anyone confirm that for me?
Lastly (please don't beat me up here as I got this bike as a motor, frame, and an ice cream bucket of bolts) Is there supposed to be a rubber plug in these holes? I see 4 holes, but I am not sure if they are supposed to have a plug in them. The manual does not appear to make me think that they should be plugged, but I also can't seem to find a good picture.
As always I appreciate all the help!
78 KZ650 B
- pnedac
Also , should this one be plugged because of the switch to gravity fed?
Attachment 2014-05-0716.18.20.jpg not found
Lastly, I think these holes should be open, but just checking.
Attachment 2014-05-0716.18.40.jpg not found
Any help is appreciated. I think I am almost there!
78 KZ650 B
Attachment 00004_2014-05-07-2.jpg not found
Attachment 00005_2014-05-07.jpg not found
Attachment 00006_2014-05-07-2.jpg not found
