- Thank you received: 680
removing smog breather thing from 1980 KZ750 E1
- DoctoRot
07 Apr 2014 00:42 #628147
by DoctoRot
removing smog breather thing from 1980 KZ750 E1 was created by DoctoRot
Is it bad to remove the emissions stuff from the kz750E? My Kz1000 had it removed when i bought it, just a hose crossing over form reed valve cover to cover and the hole in the air box plugged. Im considering removing it completely as it just gets in the way doing maintenance.
- loudhvx
- Thank you received: 1616
07 Apr 2014 07:30 #628173
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic removing smog breather thing from 1980 KZ750 E1
If it is working properly, removing it won't affect running. It just means a little more unburnt fuel will go out of the exhaust.
If it is leaking vacuum, then removing it will make the bike run a little richer.
Usually, when it malfunctions, you will get backfiring through the exhaust system when you close the throttle.
1981 KZ550 D1 gpz.
Other links.
