running rich
- koolaid_kid
Re: running rich
27 Feb 2014 18:30Do this part first, then change the oil and filter.Patton wrote: Would also sniff-test the crankcase oil and examine its physical quality, because the oil may have become contaminated (diluted) with raw gasoline from the overflowing carbs.
If so, don't run the engine anymore until the oil and filter have been changed and the overflow issue resolved.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
Re: running rich
27 Feb 2014 18:46 - 27 Feb 2014 18:47koolaid_kid wrote:No disrespect intended, but in many cases that increases the likelihood of the floats being the issue. I picked up a set of carbs for cheap and my GPz for cheap for exactly the same reason: the floats were set incorrectly.Mark Stark wrote: 650ed the carbs have been rebuilt.
+1 !
There's really nothing much to "rebuild" on the 1979 KZ650 carbs. They are the VM24SS carbs. No diaphragms or other touchy stuff to speak of. So in "rebuilding" them, did someone screw up the float tangs or float valves? Maybe. I would check the fuel level using the clear tube method to see if they did. Ed
Last edit: 27 Feb 2014 18:47 by 650ed.
- Mark Stark
Re: running rich
27 Feb 2014 18:50
hey koolaid_kid! no worries. but I see your point! ill try the oil sniffin and oil change. hopefull that's the case. I just find it weird that the bike wont start with the choke fully on. sorry guys im just new to all of this.
1979 Kawasaki KZ650
Stark Industries
Stark Industries
- fastidiots
Re: running rich
01 Mar 2014 01:35
Just ran into this myself on a KZ750. carbs were just rebuilt, I checked and set floats, and bench synced the carbs. Bike fired up and ran real nice so I went for a test ride. Got about 3 miles away and the bike died from an idle and wouldnt restart...plugs flooded. I could pull the plugs and air out the cylinders and it would try to start once and then nothing (kick start only at this time). Finally pulled out the air filter and then it started and ran! Turns out the filter foam needed a good cleaning and now it seems to run fine!
82 KZ1000 J
76 KZ750 B1
76 KZ750 B1
- fastidiots
Re: running rich
02 Mar 2014 15:53
just to update...rode my bike next day and still had the same problem. Bike has a cylindrical filter screen that had foam filter material put through the center and then folded back over both ends on the outside to put a layer of foam on both the inside and outside of the screen. I took the foam back off and cut it in half and put it back on just the outside of the screen. NOW the bike idles smoothly and runs great. No more loading up and running too rich.
82 KZ1000 J
76 KZ750 B1
76 KZ750 B1
The following user(s) said Thank You: Troyn
Re: running rich
02 Mar 2014 16:20fastidiots wrote: just to update...rode my bike next day and still had the same problem. Bike has a cylindrical filter screen that had foam filter material put through the center and then folded back over both ends on the outside to put a layer of foam on both the inside and outside of the screen. I took the foam back off and cut it in half and put it back on just the outside of the screen. NOW the bike idles smoothly and runs great. No more loading up and running too rich.
I sounds someone installed a home-made filter or tried to re-line an original one. I suggest you go ahead and buy a new filter element for the bike so you know it is filtering properly but still permitting proper air flow. Ed
- Mark Stark
Re: running rich
04 Mar 2014 08:00
hey guys! thanks for all the good advice. i drained the carbs this past weekend. checked the spark plugs and noticed they were very black. cleaned them up and checked the spark gap. i just have to get a hotter plug and that should solve the gasoline smell.
1979 Kawasaki KZ650
Stark Industries
Stark Industries
- Mark Stark
Re: running rich
04 Mar 2014 08:01
also re adjusted the air screws to 1 1/2 turns
1979 Kawasaki KZ650
Stark Industries
Stark Industries
- Troyn
Re: running rich
14 Mar 2014 17:18 - 15 Jul 2014 05:55
New air filter = good!
1983 kz750 ltd shaft, 4-cyl, stock everything
Last edit: 15 Jul 2014 05:55 by Troyn.
