running rich
  • Mark Stark
  • Mark Stark's Avatar Topic Author
running rich
27 Feb 2014 09:57
#623528
hey guys. i own a 1979 kz650 and i have a quick question. my bike i running really rich and i wanted to know how to fix said problem. right now i believe the carbs are flooded. if i put the choke on all the way the bike will die. so i thing believe there is too much fuel passing through. i appreciate the help guys!
1979 Kawasaki KZ650
Stark Industries
  • koolaid_kid
  • koolaid_kid's Avatar
Re: running rich
27 Feb 2014 12:25
#623541
I would check the needle and seat for each carb, and check the float level as well. Also check your petcock to make sure it is not leaking.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
  • Topper
  • Topper's Avatar
Re: running rich
27 Feb 2014 12:49
#623544
koolaid_kid wrote: I would check the needle and seat for each carb, and check the float level as well. Also check your petcock to make sure it is not leaking.
+1 to checking float levels.
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
  • Mark Stark
Re: running rich
27 Feb 2014 13:15
#623548
the petcock isnt leaking. so how would i go about checking the float level? also when i got it back from the garage a while ago they said i would have to get it rejetted.
1979 Kawasaki KZ650
Stark Industries
Re: running rich
27 Feb 2014 13:22
#623549
If your bike was running fine before you dropped it why rejet? Does your shop truly believe dropping the bike caused a jetting problem? :blink: Is there something you're not telling us? Did you remove the air filter or change the exhaust? In any event, look at the link below for checking the fuel level in the carbs. Ed
www.kzrider.com/forum/2-engine/592868-oi...ed-spark-plug#623481
  • Mark Stark
Re: running rich
27 Feb 2014 13:27
#623550
no that just recently happened. i got it back from the shop on nov 23. its been running rich this whole time. you can smell fuel when riding.
1979 Kawasaki KZ650
Stark Industries
  • thoraxotool
  • thoraxotool's Avatar
Re: running rich
27 Feb 2014 13:51
#623551
I had a similar issue with my 550.
Granted, my fuel economy isn't prefect but I did at least get rid of the gas smell.
I cleaned the carbs, synchronized them and then adjusted the idle speed. VoilĂ , gas smell gone.
1982 KZ550 LTD
The following user(s) said Thank You: Mark Stark
Re: running rich
27 Feb 2014 14:29
#623555
Mark Stark wrote: no that just recently happened. i got it back from the shop on nov 23. its been running rich this whole time. you can smell fuel when riding.
OK. Given that, does your bike have the stock carbs, air filter, and exhaust system? If so, your carbs need to have stock jetting, needle position, air screw and/or pilot screw position, be synchronized properly, and have the fuel level set correctly. If the carbs are set to the stock settings, the float valves are operating properly, the carbs are clean, and you have the stock air filter and exhaust system you should not be experiencing a rich fuel condition. However, if a shop or previous owner has screwed up the jetting or other settings, the fuel levels are not correct, or you have a float valve sticking open, you could experience a rich fuel condition even with stock air filter and exhaust. Ed
  • Mark Stark
Re: running rich
27 Feb 2014 16:01 - 27 Feb 2014 16:06
#623569
hey thoraxotool! im new to all this stuff. so how would i go about doing all of that.
1979 Kawasaki KZ650
Stark Industries
Last edit: 27 Feb 2014 16:06 by Mark Stark.
  • Mark Stark
Re: running rich
27 Feb 2014 16:04
#623570
650ed the carbs have been rebuilt.
1979 Kawasaki KZ650
Stark Industries
  • koolaid_kid
Re: running rich
27 Feb 2014 16:50
#623571
Mark Stark wrote: 650ed the carbs have been rebuilt.
No disrespect intended, but in many cases that increases the likelihood of the floats being the issue. I picked up a set of carbs for cheap and my GPz for cheap for exactly the same reason: the floats were set incorrectly.
1983 GPz 750
Re: running rich
27 Feb 2014 18:07
#623574
Would also sniff-test the crankcase oil and examine its physical quality, because the oil may have become contaminated (diluted) with raw gasoline from the overflowing carbs.
If so, don't run the engine anymore until the oil and filter have been changed and the overflow issue resolved.
Good Fortune! :)
