running rich
- Mark Stark
1979 Kawasaki KZ650
Stark Industries
- koolaid_kid
- Thank you received: 99
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
- Topper
- Thank you received: 133
koolaid_kid wrote: I would check the needle and seat for each carb, and check the float level as well. Also check your petcock to make sure it is not leaking.
+1 to checking float levels.
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
- Mark Stark
1979 Kawasaki KZ650
Stark Industries
- Thank you received: 2829
www.kzrider.com/forum/2-engine/592868-oi...ed-spark-plug#623481
- Mark Stark
1979 Kawasaki KZ650
Stark Industries
- thoraxotool
- Thank you received: 5
Granted, my fuel economy isn't prefect but I did at least get rid of the gas smell.
I cleaned the carbs, synchronized them and then adjusted the idle speed. VoilĂ , gas smell gone.
1982 KZ550 LTD
Mark Stark wrote: no that just recently happened. i got it back from the shop on nov 23. its been running rich this whole time. you can smell fuel when riding.
OK. Given that, does your bike have the stock carbs, air filter, and exhaust system? If so, your carbs need to have stock jetting, needle position, air screw and/or pilot screw position, be synchronized properly, and have the fuel level set correctly. If the carbs are set to the stock settings, the float valves are operating properly, the carbs are clean, and you have the stock air filter and exhaust system you should not be experiencing a rich fuel condition. However, if a shop or previous owner has screwed up the jetting or other settings, the fuel levels are not correct, or you have a float valve sticking open, you could experience a rich fuel condition even with stock air filter and exhaust. Ed
- Mark Stark
1979 Kawasaki KZ650
Stark Industries
- Mark Stark
1979 Kawasaki KZ650
Stark Industries
- koolaid_kid
No disrespect intended, but in many cases that increases the likelihood of the floats being the issue. I picked up a set of carbs for cheap and my GPz for cheap for exactly the same reason: the floats were set incorrectly.Mark Stark wrote: 650ed the carbs have been rebuilt.
1983 GPz 750
- Thank you received: 2098
If so, don't run the engine anymore until the oil and filter have been changed and the overflow issue resolved.
