Kawasaki KZ750E with cone filters
  • karoliens
  • karoliens's Avatar Topic Author
03 Feb 2014 10:13
#620978
Hello,
I have Kaawasaki KZ750E with 4xCV34 carbs and cone filters on each. Could you give me what base adjustment should be of the pilot/mixture screw? Idle for these bikes should be 1000-1100rpm? The main problem is that if/when I start the bike ant give some rpms they drop slowly. So this is the symptom of rich or lean mixture? Thank you.
83' Kawasaki KZ750E-L2
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: Kawasaki KZ750E with cone filters
03 Feb 2014 10:58
#620980
1) please fill out your profile and tell us about you and your bike(s).
2) this site has a search function, CV carbs with pod filters have been covered before, many times
post a pic of your carbs and filters, some filters will work and some don't
3) the hanging/slow to return to idle is typical of a lean condition
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • undiablo
  • undiablo's Avatar
03 Feb 2014 11:09
#620982
Check for air leaks in carb to engine boots.
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
  • karoliens
03 Feb 2014 12:32
#620994
Boots seems to be OK. And how much I should unscrew pilot screw? With stock air box and filter manual says 2 turns out. Here is the photo of the setup:
[img
  • Nebr_Rex
  • Nebr_Rex's Avatar
03 Feb 2014 12:46
#620995
karoliens wrote: Boots seems to be OK. And how much I should unscrew pilot screw? With stock air box and filter manual says 2 turns out. Here is the photo of the setup:
[img
Are those K&N filters? The filters that have problems with CV type carbs are the cheap
Emgo filters. They block off the air ports on the intake side of the carb and really mess up
the signal to the jets. K&N's and Uni's are better at not blocking those ports.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
  • karoliens
03 Feb 2014 12:51
#620998
Yes they are cheap ones. K&N ones have open end you mean?
  • JR
  • JR's Avatar
03 Feb 2014 13:24 - 03 Feb 2014 13:25
#621003
I have a KZ750E1 which is the 1980 model. When I saw "KZ750E" I thought E1, E2 or E3 which were 80, 81 and 82 models with Keihin CV34 carbs but yours is an 87: which would make it a ZX750 and it probably has Mikuni BS34 CV Carbs.
Having said that, I have had K& N pods on mine and have had the pilot mix screw out as much as 3 turns. It is easy to experiment. Like the guys say check for air leaks.
Also, some cheap pods have an internal lip which can block off some of the inlets on the carbs. See the areas circled in red in the attached pics. The carbs in the pic are my Keihin CV34s but your should be similar. K&N pods do not block these inlets. Check the inside of your pods to see it there is anything which can block or partially block these inlets/holes.
Last edit: 03 Feb 2014 13:25 by JR.
  • steell
  • steell's Avatar
03 Feb 2014 15:17
#621012
JR wrote: I have a KZ750E1 which is the 1980 model. When I saw "KZ750E" I thought E1, E2 or E3 which were 80, 81 and 82 models with Keihin CV34 carbs but yours is an 87: which would make it a ZX750 and it probably has Mikuni BS34 CV Carbs.
ZX750E would be a 84-85 750 Turbo. 83-85 ZX750A was a GPz750 with Mikuni carbs.
I think he/she is just mistaken on the model year.
  • JR
  • JR's Avatar
03 Feb 2014 17:27 - 03 Feb 2014 17:28
#621017
I'm sure you're right steell. It does look like an early 80s motor with a mid 80s tank so 87 has got to be a typo
Last edit: 03 Feb 2014 17:28 by JR.
  • steell
  • steell's Avatar
03 Feb 2014 22:03
#621040
It looks to me like a 80 or later KZ750H with a GPz750 (82?) tank. A full pic of the bike and the sticker on the steering head would help clear things up.
There's another thread in the Chassis Forum about a 750H with a GPz tank and seat. Strange to have two pop up at the same time.
  • karoliens
03 Feb 2014 22:51 - 03 Feb 2014 23:39
#621043
I think I mixed up model year. I will check when I get home. But for sure on chassis there was written K750E... Here is the photo of the bike:
[img
P.S. I googled and from the pics i could tell that I have CV34. I will confirm it later.
Last edit: 03 Feb 2014 23:39 by karoliens.
  • yeekim
  • yeekim's Avatar
04 Feb 2014 04:42
#621052
Same issue with chinese 5$ pods!
Any experience with UNI pods?
Ex nihilo nihil fit!
