carb swap?
  • yeekim
  • yeekim's Avatar Topic Author
carb swap?
18 Jan 2014 01:58 - 18 Jan 2014 02:14
#619058
No eBay APP ID and/or Cert ID defined in Kunena configurationHi!
On my 750 four's I have 1 Mikuni and 1 Keihin carb.
Both with same in- and out diam.
As one ride is a primary one and second spare parts(scrambler) project, I was thinking, whitch one is better:
Keihin or Mikuni?
And has anyone used this:
Ex nihilo nihil fit!
Last edit: 18 Jan 2014 02:14 by yeekim.
  • JR
  • JR's Avatar
Re: carb swap?
18 Jan 2014 08:29
#619065
The early (80, 81 & 82) 750 4s came with the Keihin CV34 carbs and I think from 83 and up Mikuni BS 34s were used. I actually like my Keihin s and have had no problems when I jetted them for pods and then back to air box for the original look. However, I think my viewpoint is a minority one. Most people seem to prefer the mikuni carbs. There are more of them out there and I hear it's easier to get parts.
sorry I can't help regarding the jet kit.
The following user(s) said Thank You: yeekim
  • yeekim
Re: carb swap?
18 Jan 2014 13:18
#619081
TNX!
Only benefit I see right now is, that MIKUNI has adjustable needle hight!
On KEIHIN it's "complicated" ;)
The reason for asking about SIGMA Jet-kit's is: PRICE
  • Bdog
  • Bdog's Avatar
  • Sweep the leg johnny!!!
Re: carb swap?
14 Mar 2014 12:00
#625156
The Mikuni BS34's seem to work better on my 810. The Kiehin's have a butterfly that chokes the air and gets in the way of velocity, wear as the Mikuni's have an enriching circuit that provides more gas I think to create the cold start choke affect. Difference was night and day, especially higher up in the rev range.
Brandon
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
  • WhiskeyB
  • WhiskeyB's Avatar
Re: carb swap?
17 Mar 2014 17:21
#625588
My 82 GPz750 has the stock Mikuni BS34 carbs, and they are great with the stock airbox. CV carbs are popular choice for OEMs for a reason. They require a lot less tuning work, in general, and offer good mid-range and transitional throttle response, which is nice for a street bike/daily rider. They don't tend to work well with pod filters, however, as the operation of the diaphragm/slide is designed for the use of the airbox.
The Kehins on my 75 CB550K and 77 CB750F2 are non-CV. The advantages are that they take to pods well, and there's no delicate diaphragm to worry about. The down side is that they require a fair bit more tuning if you want them to run well at anything less than flat-out WOT riding (the same sort of advantages and problems you get with flatslides).
It depends on what you want from the bike. Race-built vehicles aren't actually much fun on the street, in my experience.
Just my $0.02
1982 GPz 750
  • yeekim
Re: carb swap?
29 Apr 2014 10:03
#630806
Hi!
So made the swap- it runs just great on Mikuni's BUT.....
Only when engine is warm :angry:
When cold, idles poorly, doesn't hold the revs, dies out in first 2 or 3 start attempts...
But to ride- it just brings a smile on my face compare tu Keihin's :P
Fast response, good accel'
Any ideas, why cold?
  • undiablo
  • undiablo's Avatar
Re: carb swap?
29 Apr 2014 11:35
#630811
I have 2 sets of Keihins CV34 and they work nice for me. However I did not have the chance of testing the MIKUNIS BS34.
In my opinion, early KEIHINS are better because they have 3 jets:
Pilot - Main jet - secondary Main Jet.
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
  • Grady1966
  • Grady1966's Avatar
Re: carb swap?
30 Apr 2014 20:17
#630981
Sorry can't help you I am new on here I have a 1976 KZ 400. Very clean , 3000 miles on it I have learned that 1976 carb parts are so hard to come by verses say1975 , or 1977. Will these interchange with a1976. Or what will if any ,any input would be very appreciated, thanks. Carb swamps from early or later years.
