Jet kits?
  • Serpent7
  • Serpent7's Avatar Topic Author
  • Nothing professionally, only for fun...
Jet kits?
15 Jan 2014 09:15
#618699
I have a '79 KZ1000, upgrades include Dyna coils, wires, and ignition. K&N individual pod filters, and K&N oil filter. 4 into 1 sidewinder exhaust, and Kerker pipe with no baffle.
I currently have a stage 1 jet kit on my mikuni 28 carbs. I was wondering, should I upgrade to a stage 2, or stage 3 jet kit? My bike runs well, and idles just OK now.
What are the benefits of upgrading my jets in my carb to a stage 2, or 3?
If you had this same set-up, which jet kit would you go with?
How will going to a stage 2, or stage 3 jet kit affect my gas mileage, and put-puts around town?
19 Audi Q5
14 Volkswagen Touareg X
97 Honda Shadow Spirit
79 Kawasaki KZ1000 st
79 Volkswagen Transporter
73 Volkswagen Thing
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: Jet kits?
15 Jan 2014 10:27
#618713
If it was me, I'd do a ton of searching on this site and re-jet using the suggestions that I found and save a bunch of money over a jet kit.
A normal set up would be either 2.5-3 turns out on the stock pilot or 1 size larger and a couple steps up larger on the main. Perhaps shim the needle if needed. Done!
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
The following user(s) said Thank You: Serpent7
  • koolaid_kid
  • koolaid_kid's Avatar
Re: Jet kits?
15 Jan 2014 12:41 - 15 Jan 2014 12:42
#618728
IIRC, your engine is the only KZ with VM carbs that DynoJet makes a kit for.
Your bike is on the needle most of the time, and DynoJet claims they spend the bulk of their time refining the taper of the needle for maximum performance. Since you already have the needle, all you need are larger main jets. 2-3 sizes might just do it.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
Last edit: 15 Jan 2014 12:42 by koolaid_kid.
  • sbc1320
  • sbc1320's Avatar
Re: Jet kits?
15 Jan 2014 12:57
#618731
My 1000 came to me with the Dyanjet Stage III kits installed. Mine has 145 mains and stock pilots I believe from going over my paperwork. According to the cross reference my Dynojet 145's equal to a 131 main jet. My bike is setup the same as your's, but has MTC 10.5 pistons on a stock bore. My carbs are 28 pumpers and work well.
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
  • koolaid_kid
Re: Jet kits?
15 Jan 2014 13:56
#618747
Serpent7, in case you don't know, DynoJet uses a different numbering system on their jets. So it sounds like you can get OEM jets in 130 to do the trick, or 145 from DynoJet. Not sure on the price of OEM jets, but I believe the DynoJet jets are $2 each.
1983 GPz 750
  • Serpent7
Re: Jet kits?
16 Jan 2014 09:11
#618834
sbc1320 wrote: My 1000 came to me with the Dyanjet Stage III kits installed. Mine has 145 mains and stock pilots I believe from going over my paperwork. According to the cross reference my Dynojet 145's equal to a 131 main jet. My bike is setup the same as your's, but has MTC 10.5 pistons on a stock bore. My carbs are 28 pumpers and work well.
So…. (and I'm new to the carb scene) All I heed to do is purchase the main jets in either 131, or 130 (oem), or Dyno Jets 145's and I'm at a stage 3 jet kit? How many main jets do I need?
19 Audi Q5
73 Volkswagen Thing
  • sbc1320
  • sbc1320's Avatar
Re: Jet kits?
16 Jan 2014 09:39
#618836
You would need 4 main jets. Mine is equal to a 131, but they only come in increments of 2.5 so if stock jets are used it would be a 130 or a 132.5. Mine has added compression so you shouldn't need quiet as big as mine I would think. Once you run it hard you are supposed to shut the engine off and check the plugs to make sure they are not too lean. Too much idling and you can't read the plugs. You would probably come in at around a 120 to a 125(stock jets, not Dynojets) I am guessing.
What size are in your's now?
  • koolaid_kid
Re: Jet kits?
16 Jan 2014 11:38
#618852
Yes, that would put you at a Stage 3 kit. Personally, when I am targeting a particular number, such as 145, I prefer to go ahead and order the size below and above, just in case. You will end up with 12 unused jets, but you will be able to fine tune it without waiting for more jets to arrive if 145 is not the perfect number.
1983 GPz 750
  • Serpent7
Re: Jet kits?
16 Jan 2014 16:53
#618880
Ok!I think I got it now... Last question is, I need needle jets, right?
19 Audi Q5
73 Volkswagen Thing
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: Jet kits?
16 Jan 2014 18:14
#618891
Buy a stage 3, all-inclusive.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • TexasKZ
  • TexasKZ's Avatar
Re: Jet kits?
16 Jan 2014 18:36
#618894
Are you sure you have a jetting problem? Why do you want to mess with them?
  • koolaid_kid
Re: Jet kits?
17 Jan 2014 05:15
#618923
Serpent7 wrote: Ok!I think I got it now... Last question is, I need needle jets, right?
Nope. Just main jets.
1983 GPz 750
