Used (16065-1135) carburetor holders
  • daveo
  • Topic Author
  • Premium Member
08 Jan 2014 21:29 #617852 by daveo
Anyone know a trick to attaching previously used (excellent condition) carburetor holders to achieve a good seal? :unsure:
The set I put on yesterday was originally mounted for a short while on a different head, and removed/stored for future use when that head was replaced a couple years ago.
The rubber mating surface is well-molded and heat-set with no cracks or checking, but the rest of the holder rubber is pliable.
The set does not mate well, but allows some outside air to get sucked into the motor. I did not use sealant when installing them, figuring they would just re-shape to this head when tightened down, but noooooooooo... I tested them by spraying carb cleaner onto the joints while the engine was idling, and there were noticeable changes in idle speed.
So, what's next? Perhaps it makes more sense to just get a new set. I don't want to risk sucking something used to seal them into the motor.
It seems like a good place for an O-ring.
1982 KZ1100-A2
08 Jan 2014 21:47 #617853 by koolaid_kid
Replied by koolaid_kid on topic Used (16065-1135) carburetor holders
Are they supple, soft?
I have read where Wintergreen oil will soften them up.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
  • daveo
  • Topic Author
  • Premium Member
08 Jan 2014 22:03 - 08 Jan 2014 22:05 #617854 by daveo
Replied by daveo on topic Used (16065-1135) carburetor holders
They are like new, except the contact ring at the head. That is where its like plastic from the heat.
1982 KZ1100-A2
Last edit: 08 Jan 2014 22:05 by daveo.
09 Jan 2014 02:45 #617858 by ZERO
Replied by ZERO on topic Used (16065-1135) carburetor holders
I use Kawibond sealant. It's fuel resistant. If there's any doubt, Dont use them. Few things will damage an engine as quickly as a lean condition caused by air leaks. For me, they look good. Use some sealant.
Only Kawasakis have a soul 1977 Kawi KZ1000 special 2000 Kawi ZRX1100
09 Jan 2014 05:25 - 09 Jan 2014 07:41 #617867 by 650ed
Replied by 650ed on topic Used (16065-1135) carburetor holders
I would replace them. Sealant usually only serves as a temporary fix at best. The good news is that Kawasaki.com shows them as "Active" so they should still be available. Partzilla lists them at $16.45 each. Ed
find.partzilla.com/?r=t&q=16065-1135&x=6&y=6
Attachment 00003_2014-01-09.jpg not found
Last edit: 09 Jan 2014 07:41 by 650ed. Reason: Fat Fingers!
09 Jan 2014 06:26 #617872 by koolaid_kid
You might also check with Z1Enterprises. They show an equivalent set for $60.30
1983 GPz 750
09 Jan 2014 07:43 - 09 Jan 2014 07:43 #617891 by 650ed
Sorry about my typo in my previous posting. The price is $16.45 each NOT $126.45 each. I fat fingered that price badly! I went back and corrected it. Ed
Last edit: 09 Jan 2014 07:43 by 650ed.
09 Jan 2014 07:56 #617892 by koolaid_kid
LOL. I thought you meant per set of 4. Not much more than Z1E.
I bought mine at Z1E and r\they work great.
1983 GPz 750
  • daveo
  • Topic Author
  • Premium Member
09 Jan 2014 08:25 #617901 by daveo
Any thoughts on OEM Genuine Kawasaki vs. K&L (regarding quality), regardless they have the same part number molded into the rubber? Perhaps a less-costly, inferior rubber compound is used in aftermarket manufacturing.
What I'm getting at, is the price disparity between OEM and aftermarket. An example...K&L carburetor kits for the BS34 contain fuel float valves that are not quite the same as the OEM Genuine Kawasaki (Mikuni) part. The OEM float valve currently sells for twice the price of a whole K&L kit! On close inspection, the parts are quite different, though designed to do exactly the same thing (which one does flawlessly).
1982 KZ1100-A2
  • daveo
  • Topic Author
  • Premium Member
09 Jan 2014 08:34 #617903 by daveo
ZERO wrote: I use Kawibond sealant. It's fuel resistant. If there's any doubt, Dont use them. Few things will damage an engine as quickly as a lean condition caused by air leaks. For me, they look good. Use some sealant.
What if a swatch of rubber sealer breaks loose and gets lodged between the valve and it's seat? :ohmy: OUCH!
1982 KZ1100-A2
09 Jan 2014 08:48 #617908 by RonKZ650
Replied by RonKZ650 on topic Used (16065-1135) carburetor holders
Yamabond #4 works great. Probably same as the kawasaki bond. All you need is a thin coat of it. No worry of sucking any into the engine, and even if it did, no adverse effects would result.
09 Jan 2014 08:55 #617910 by ZERO
Then you've used too much! I'm talking about a skin of it. Funny thing....I just rebuilt an engine for a friend and he insisted on re-using his intakes with deep cracks visible. His fix? black R.T.V smeared all over the outside. Generally, just put on a smear and spread it with a finger on the attaching surface. Install the intake and then, with a rag, wipe off the extra from the inside with a rag. I've never seen an issue with an engine swallowing sealant and doing engine damage. I've been doing this for nearly 40 years.Valve springs are strong. seats are smooth....Not a nice environment for rubber sealer.(I HAVE seen spark plugs fouled with a chunk of it.) Its also neat to use allen head bolts instead of screws and find some small washers to fit underneath. Really, the best thing to do is replace them..each time. But to me, yours look good. (enough) Only my 2 cents.
