Rebuild kit for KZ650 B- How to take apart?
- pnedac
18 Nov 2013 08:47 #613351
by pnedac
78 KZ650 B
Rebuild kit for KZ650 B- How to take apart? was created by pnedac
:huh:
Thank you in advance for any help you can offer. I purchased a rebuild kit for my KZ650 1978 and I am taking it apart when I see that I have a new diaphram, but I can't seem to figure out how to get this square plastic thing out of the old piece and how to add it in between the new diaphram. the kit also came with two o rings that I do not see in the original petcock. Could these be for other models and just not needed for my bike? It is a 78 KZ650 B that I am almost done bringing back from the grave.
Any help is appreciated.
Thank you,
Pnedac
Thank you,
Pnedac
78 KZ650 B
- pnedac
18 Nov 2013 10:42 #613366
by pnedac
78 KZ650 B
Replied by pnedac on topic Rebuild kit for KZ650 B- How to take apart?
By the way the piece that I was referring to is the Nylon Spacer that sits between the diaphragm that I cannot see how to get out from between the old one and I also can't see how to get it into the new one.
I think if I can figure one of these out then the other will tell the story.
Thank you,
Thank you,
78 KZ650 B
- Thank you received: 1656
18 Nov 2013 10:55 - 18 Nov 2013 11:38 #613367
by martin_csr
Replied by martin_csr on topic Rebuild kit for KZ650 B- How to take apart?
What rebuild kit? For the petcock? If so, you kinda have to fold & pull off the old diaphragm thru the hole in the middle of that square plastic spacer, then fold & push the new diaphragm in place, again thru the hole. It's been a while, but I think the diaphragm can only go thru one way. As for the o-rings, one may be for the tap lever (some models may not use that o-ring). I think the larger o-ring is for the petcock where it contacts the tank - it fits into the groove of the petcock body.
Last edit: 18 Nov 2013 11:38 by martin_csr.
The following user(s) said Thank You: pnedac
- pnedac
18 Nov 2013 11:06 #613371
by pnedac
78 KZ650 B
Here is a link to the petcock rebuild kit that I have:
www.z1enterprises.com/ItemDetails.aspx?i...um%29&item=KL18-2699
I just could not see how the spacer can be removed without breaking something which is what I would like very much to avoid. I will take your advice and see if I can make something happen. Also thank you for the note about the o rings. I couldn't see that they belong to this petcock, but I know that sometimes they cover a number of models.
Cheers,
Cheers,
78 KZ650 B
18 Nov 2013 11:32 - 20 Nov 2013 05:33 #613374
by martin_csr
In the Z1Ent link you can see the diaphragm o-ring side. You have to push that thru the plastic spacer. The other side has the large disk for the spring & I don't think it will fit thru the hole as easily. If you do an internet image search for petcock diaphragm, you might find some photos of the spacer n stuff.
Last edit: 20 Nov 2013 05:33 by martin_csr.
- Thank you received: 2829
18 Nov 2013 12:44 #613390
by 650ed
Replied by 650ed on topic Rebuild kit for KZ650 B- How to take apart?
Here are the instructions from the Kawasaki Service Manual and the diagram from Kawasaki.com. Ed
Attachment 00002_2013-11-18.jpg not found
Attachment 00003_2013-11-18.jpg not found
- pnedac
18 Nov 2013 13:42 #613400
by pnedac
78 KZ650 B
Thank you 650ed for posting this. Very helpful. The issue is not so much in how to assemble, but how to get the nylon spacer out of the old diaphragm and into the new one without breaking anything. I will be home soon and look this over again, but it did not appear that there was a viable way to get it off without some trouble. I wlll post a picture of my issue too in a bit here.
Thanks!
Thanks!
78 KZ650 B
18 Nov 2013 13:53 #613403
by martin_csr
There's nothing to it really. The old diaphragm may be stuck to the nylon spacer, but that's no big deal.
- pnedac
18 Nov 2013 16:06 #613415
by pnedac
78 KZ650 B
The old rubber part of the diaphragm was stuck to the nylon spacer, but that is not the problem. The nylon spacer is "locked" in because there is no mechanism to get it out from either side of the unit. On the one side is the large disc and on the other side there is a outer lip that is larger than the spacer, again making it so that it won't come out. These pieces don't seem to screw apart or anything so I am feeling pretty stuck on this.
Attachment photo2-3.JPG not found
Attachment photo1-3.JPG not found
78 KZ650 B
18 Nov 2013 17:09 - 18 Nov 2013 17:10 #613420
by 650ed
Last edit: 18 Nov 2013 17:10 by 650ed.
- pnedac
18 Nov 2013 17:22 #613421
by pnedac
78 KZ650 B
I notice that the site that I got the kit from has a note that says "Vacuum Diaphragm requires (where applicable) the nylon spacer from the diaphragm being replaced." I can see with the new diaphragm that there is a space in there for the nylon spacer, but for the life of me I can't figure out how to get it in there. Somebody make me feel stupid! I welcome it.
78 KZ650 B
19 Nov 2013 05:54 - 20 Nov 2013 05:34 #613452
by martin_csr
Does the diaphragm plunger move? ... the deal in the center. Have you got any other pics of the petcock? My guess is that you may have to get a replacement petcock. Z1Enterprises sells an aftermarket Suzuki vacuum petcock that should fit your tank.
Try doing a google image search for 1978 KZ650 petcock diaphragm to see if anything looks familiar. Here's a topic - I think you have to log-in to see the photos. KZ650.Info - Petcock rebuilding
Last edit: 20 Nov 2013 05:34 by martin_csr.
