Does this sound like a vacuum leak problem?
- delta 224
- Thank you received: 2829
find.partzilla.com/?r=t&q=16065-1027&x=10&y=9
kzrider.com/forum/10-new-members/589649-...r-savannah-ga#594587
Attachment 00003_2013-11-13-2.jpg not found
- peavylotus
- Movin on up
- Thank you received: 15
This website is on carb theory on mikuni carbs. Its well written and very easy to understand.
1980 KZ 1045 LTD Currently Workin' It Out
- Cynjut
- Thank you received: 26
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
- Thank you received: 2098
peavylotus wrote: I'm not too fluent with carburetors but I know that trying to diagnose further without leak free boots is a pain in the A. I was trying to adjust my carbs with leaking boots and I never got them right because of it.
Thanks for the link!
- delta 224
delta 224 wrote: I took off the boots, put some gasket sealant around the lip and put them back on. After it all settled it ran much better. Hopefully this is permanent. Also I finished my top box project
Likely not very permanent.
Let us know what sealant and how it works, as most reports show only temporary success, with sealant not being both heat-proof and fuel-proof for the long term.
Am recalling that Yama-Bond is superior to silicone based sealers in this particular application.
www.z1enterprises.com/ItemDetails.aspx?i...+1194&item=TU53-0395
The product is promoted as follows:
ThreeBond 1194 is a semidrying liquid gasket whose major component is special synthetic rubber. After it is applied and dried, it will form a rubber-like elastic body. Since it excels in padding property, it shows a high sealing effect on bonded surfaces that have poor flatness and large clearance. In addition, it has excellent resistance to water, oil and gasoline.
High padding property.
It shows an excellent sealing effect not only on normal bonded surfaces, but also on bonded surfaces with large clearance.
Excellent resistance to vibration and impact.
After applied and dried, it will form a rubber-like elastic body and exhibit excellent resistance to vibration and impact.
Excellent resistance to high and low temperatures.
It keeps stable rubber elasticity in a wide temperature range from -40°C to 150°C.
Excellent resistance to water and oil.
Effective in preventing leak from threaded portions.
Sealing of flange surfaces and threaded portions.
Applicable to sealing of flange surfaces having large clearance.
For sealing other coolants.
