New 1978 Z1R Owner Savannah GA
  • Hooker254
  • Hooker254's Avatar Topic Author
01 Jul 2013 10:08
#594579
Hello to all, I am a proud new owner of a 1978 KZ1000 Z1R. I bought the bike for 340 dollars, and it came with everything that is needed to rebuild (lets call it the bike in a box). Some very cool things came with this bike, it has original Dynamag 3 spoke magnesium wheels bought in 1986, along with S&W rear shock (light blue) also brand new RC 70mm pistons as in Russ Collins Engineering pistons. The crank was balanced back in 1990 by Falicon ( this bike has been apart since 88-89) Not too much missing or broken, though I am in need of the plastic cover that goes over the instrument cluster(mines broken), and a smoke windscreen. My goal it to get the engine all built up by summers end, and running as well. I am looking for any and all help suggestions, things to be careful of and so forth so I can get this awesome beast back on the road like it should be.
Thanks James
Re: New 1978 Z1R Owner Savannah GA
01 Jul 2013 11:28 - 01 Jul 2013 11:31
#594587
Welcome aboard!
Here are some tips that you may find helpful:
Many newbies and not so newbies run into the same problems or issues with their bikes which could be easily avoided with a little preparation. Here are a couple recommendations that I hope you will find useful.
Before working on or riding your KZ you should take a little time to become familiar with it. Simple things like checking the oil, tire pressures, etc. are explained in the Kawasaki Owner's Manual. If you bike didn't come with one (they normally are in a little holder on the bottom of the seat) you can usually find one on eBay - be sure to get one for your exact year/model.
SERVICE MANUAL
You really should buy the Kawasaki Service Manual for your bike. The factory service manual provides instructions on the various maintenance procedures and schedules for your bike, procedures for diagnosing problems, proper torque values for the various fasteners (VERY IMPORTANT), and insight into how each system on your bike works even if you are not repairing that system. Studying the manual before you attempt performing service on your bike will impart an understanding of the system you are working on which will increase the odds of success.
The manuals usually are readily available for most models on eBay and other sources; but be sure to get one that has your specific year and model in it as there are differences between the various models. I do not recommend Clymers, Haynes, or other aftermarket manuals as I have seen instances where they provide inaccurate advice. You may decide to use those to supplement the factory manual, but in my opinion they are not a suitable substitute. If you have trouble finding one for your model ask us to help.
TOOLS
Before reaching for that Phillips screwdriver to do a repair or maintenance PLEASE do yourself a big favor and visit the following link. It explains the fact that Phillips screwdriver tips will wreck the crosshead screws (they are not Phillips - they are JIS screws) on your KZ650 and tells how to easily deal with this issue so it will not be a problem.
kzrider.com/forum/21-tools/532335-budget...ewdriver-tips#532335
Before reaching for that wrench or ratchet consider the following. The bolts are steel, but your engine and front forks are aluminum. The bolts are much tougher than the aluminum and if over tightened will strip the aluminum threads. Although these can be repaired, preventing damage by applying proper torque will save you grief, time, and money. Tightening fasteners properly requires torque wrenches. Various vendors, including Snap-on, CDI, Sears, etc., market torque wrenches. The two most popular types are the bar type and micrometer type. Either will work, but the micrometer type is a bit easier to use, especially if you are tightening several fasteners with the same torque - such as cylinder head covers. You will need a torque wrench calibrated in INCH POUNDS for many of the bolts. You will also need a torque wrench calibrated in FOOT POUNDS for the larger bolts. Don't try to use the foot pounds wrench on the smaller bolts as it will not be sensitive enough at low torque settings to provide accurate torque. There are many fasteners that require low torque. These include such things as 6mm oil pan bolts, cylinder head cover bolts, etc. for which the torque in 61-78 inch pounds. These low torque bolts require a wrench that is accurate at low settings and this wrench should be graduated in inch pounds. In addition, there are numerous high torque fasteners such as the front axle nuts (51 - 65 foot pounds) or swing arm pivot shaft nuts (58 - 87 foot pounds). These require a wrench that is accurate at higher settings; this wrench should be graduated in foot pounds. Using the proper torque wrenches to correctly tighten fasteners will help prevent damage and contribute to a safe bike. The Kawasaki Service Manual will list the various torque specs for the bolts. I suggest you get the manual before buying the torque wrenches so you can decide which wrenches best meet the torque specs.
Consider buying a can of Kroil penetrating oil and use it to soak stubborn fasteners for a couple days before trying to loosen them. Remember, the original screws and bolts were installed on your bike when Jimmy Carter was President, so many of them may be hard to remove. Kroil can be bought online ( www.kanolabs.com ), at guns shows, and at some other venues.
MOTOR OIL
The ingredients in oils have changed over the years. For example, today's Castrol GTX oil (and pretty much all other AUTOMOBILE oil) is not the same as it was in the 1980's. Back then it worked great in KZ bikes. But, things have changed. Early AUTOMOBILE oils contained zinc phosphorus compounds (ZDDP) to protect engine components from metal to metal contact. This was good for engines, but it was found to be destructive to catalytic converters. Consequently, in AUTOMOBILE oils ZDDP was virtually eliminated and replaced with different chemistry generically referred to as "Friction Modifiers." These work fine and offer good protection for normal AUTOMOBILE engines. However, today's AUTOMOBILE oil "Friction Modifiers" are destructive to wet clutches. KZ bikes (and many other brands) have wet clutches. As a result of these oil chemistry changes a distinction needed to be made between those oils which are suitable for wet clutches and those which are not. That distinction was documented by the Japanese Engine Oil Standards Implementation Panel (JASO). JASO developed a number of different oil specifications for different applications. The specifications that apply to 4 stroke motorcycles fall under the "4T Specifications." Within the 4T specifications the JASO MA class oils are specifically formulated for 4 stroke motorcycles with wet clutches.
There are synthetic, semi-synthetic, and non-synthetic oils that meet the JASO-MA standard and any of them will work ok. However, using oils that are not designated as meeting the JASO-MA standard is destructive to KZ clutches.
Last edit: 01 Jul 2013 11:31 by 650ed.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
01 Jul 2013 15:55
#594610
...and welcome to KZR, you lucky turd. A Z1R in any shape for US$340 is phenomenal.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
01 Jul 2013 15:59
#594611
Hooker254 wrote: Hello to all, I am a proud new owner of a 1978 KZ1000 Z1R. I bought the bike for 340 dollars, :woohoo:
Thanks James
That NEVER happens to me! I am usually the guy doing the selling in a situation like that! :blush: Well played James and Welcome to the forum!
  • Hooker254
01 Jul 2013 16:21
#594612
Thanks for the responses so far, I will post some pics as soon as I fig out how to do so. Is one set of engine gaskets better to get than another set? Also for seal too, like I said any and all help would be greatly appreciated. Where do I put my listing of bikes in my profile?
James
01 Jul 2013 22:59 - 01 Jul 2013 23:02
#594660
Post a pic
Attachment picpostnewsite912x671.jpg not found
Add to signature
Attachment addsig.jpg not found
Also, see links in my signature.
Good Fortune! :)
Last edit: 01 Jul 2013 23:02 by Patton.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
02 Jul 2013 16:15
#594733
great score on an awesome project.
get some pics up so we can all stare in slack jawed amazement at what your hard earned dollars bought!
