KZ1000G Question
- OL BILL
04 Oct 2013 22:45 #608813
by OL BILL
Dream as if you'll live forever, live as if you'll die tomorrow.
Replied by OL BILL on topic KZ1000G Question
Wow, I going to need 1,2,6,10,12,18,20 and 21. Thanks for the fische. Explains a lot
OB
OB
- Motor Head
- Thank you received: 391
04 Oct 2013 22:49 #608815
by Motor Head
Replied by Motor Head on topic KZ1000G Question
When I looked last night i found some of it on Feebay. But not the Air flow meter. They are there for the later models, but not the 80. Not really sure what the real difference would be. There is an Air Temp sensor built into it, a set of contacts for the fuel pump so it knows the bike is drawing air, then the variable resistor for when the door swings with the incoming air. They may have changed the values? Hard to say.
- OL BILL
05 Oct 2013 00:03 #608822
by OL BILL
Do you know if the GPZ1100 FI parts same / work / interchange?
OB
OB
- Motor Head
05 Oct 2013 00:06 #608823
by Motor Head
Thee are a few parts that sre the same, but most are different. Not sure if the Air Flow Meter will work. Maybe someone else can chime in if they know one way or the other. The # of pins on the connector would be the first question.
- MFolks
- Thank you received: 540
05 Oct 2013 00:23 #608828
by MFolks
Replied by MFolks on topic KZ1000G Question
The 1981 might have an air flow that might work, but the 1982 went to a variable resistor TPS. The fuel pumps, & fuel pressure regulator should work on your 80 model.
