KZ1000G Question
- OL BILL
Thanks in advance.
OB
Dream as if you'll live forever, live as if you'll die tomorrow.
- Motor Head
- Thank you received: 391
- OL BILL
fuel pump, regulator all accounted for.
Thanks,
OB
- Motor Head
- MFolks
- Thank you received: 540
- MFolks
- OL BILL
Thanks again.
OB
- Thank you received: 2098
Here are links to wiring diagrams in KZr's FILEBASE that may be helpful:OL BILL wrote: ... 1980 classic...injected... 4500 mile one owner (before me)... I believe there is a relay, sensor or some electrical component missing... an electrical connector (I call them Bosch connectors) that is rectangular in shape with a ''wire lock'' around it where it would lock on to a component, and I cannot find anything to plug it in to. I'M thinking whatever mounts to that bracket connects to the wire / harness....
www.kzrider.com/filebase/doc_download/277-z1000g1
www.kzrider.com/filebase/doc_download/51...iring-diagram-part-1
www.kzrider.com/filebase/doc_download/51...iring-diagram-part-2
- Lt.Dan
- OL BILL
OB
- OL BILL
Attachment 001_2013-10-04.JPG not found
Attachment 003.JPG not found
- Motor Head
Look at this from the parts fiche
Then you'll see the connecting parts also to the airbox.
It's been found that the L-Jetronic Bosch system on these early Kaws share parts with the Automotive models. For one the Throttle Valve Switch, the Double Relay etc. So while I can't say 100% for sure, I would bet the Airflow Meter would also be shared, but with which car model. Well the Datsun/ Nissan Z cars would be a good place to start as the throttle switch is Identical.
