- Thank you received: 36
Accelerator pumps on 29mm smoothbores
- mtbspeedfreak
04 Sep 2013 15:06 #604805
by mtbspeedfreak
2000 ZRX 1100
1976 KZ 900- Daily Driver
Accelerator pumps on 29mm smoothbores was created by mtbspeedfreak
Is it possible to pull the accelerator pump system off of the VM28s and install them on VM29s? Obviously getting the nozzle out of the 28s and drilling/installing them in the 29s would be very tricky - has anyone done that before?
I know some rare 29s came with accelerator pumps - is it possible to retrofit a set I already have?
2000 ZRX 1100
- mtbspeedfreak
06 Sep 2013 15:37 #605229
by mtbspeedfreak
2000 ZRX 1100
Replied by mtbspeedfreak on topic Accelerator pumps on 29mm smoothbores
Anyone???
2000 ZRX 1100
- toad
- Thank you received: 7
09 Sep 2013 21:17 #605760
by toad
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
Replied by toad on topic Accelerator pumps on 29mm smoothbores
29's work great without it..
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
- BohicaBob
09 Sep 2013 22:13 #605777
by BohicaBob
Replied by BohicaBob on topic Accelerator pumps on 29mm smoothbores
But they work even better with them.
- zed1015
- Thank you received: 1581
10 Sep 2013 07:15 #605819
by zed1015
Replied by zed1015 on topic Accelerator pumps on 29mm smoothbores
It would be easier and make more sense to bore out the 28's to 29 once you have removed the nozzles.
You'll save yourself a ton of work not having to drill for the nozzles etc and also reduce the risk of turning two sets of carbs to scrap.
- razzman
18 Sep 2013 18:56 #606961
by razzman
Ride like you're invisible,
Spyder
Replied by razzman on topic Accelerator pumps on 29mm smoothbores
It has been my experience over several decades of carb restoration that the pumper system on the kz carbs to 1980 is a joke. Leave as-is. Before you try anything, check the bowls off the 28's and the 29's and check for fitment. You will be in for a surprise. On my 80 1000 shaft, I completely removed the entire accelerator assembly (as I do ALL my "pumpers" and replaced with standard bowls off an earlier year of 26's., Re-jetted accordingly, and they run like a raped ape. Unless your fuel supply is "clean room" perfect, the system becomes clogged VERY easily. Keep in mind that the function of the pump is for a very short "squirt" on rapid acceleration. They serve no purpose when the machine is under normal running condition. Amazing things can be accomplished whith proper jetting and needle clip positions. Just sayin...
Spyder
The following user(s) said Thank You: Patton
