Cleaning carbs
  • geerbangr
  • geerbangr's Avatar Topic Author
Cleaning carbs
24 Aug 2013 01:18
#602838
Cleaning carbs after 33 yrs of sitting inside. I picked up a KZ that's been parked since 1980. I'm sure the carbs are closed of. What should be my first step after pulling them off bike. A good long thorough soak in lacquer thinner ? Is it safe to soda blast the inside and outside of the carbs to help rid of the crud ?
1978 KZ 1000
I go by Jason
  • nickleo373
  • nickleo373's Avatar
Re: Cleaning carbs
24 Aug 2013 02:17
#602843
I wouldn't soda blast a carburetor. There are fragile parts inside that may get damaged. You'll want to remove all the fragile and rubber parts before doing anything I've heard dipping them overnight in pine sol works to get a lot of the grease and dirt off of them. To do a deeper cleaning you'll need carb cleaner spray, compressed air, and I use paper towels because I found wire brushes scrape the insides of the carbs. I use valvoline carb and throttle body cleaner (I found it works great). Let all the jets and needles sit overnight in a bowl of carb cleaner and then blow compressed air through them the next day. Make sure you blow carb cleaner and compressed air through the holes that you took the jets out of. It's also good to have some extra gaskets on hand because you won't know what condition yours are in until you open them up. After everything's clean just sync them and you can put them back on the bike.
1981 KZ550C LTD
"If you ain't first, you're last"
The following user(s) said Thank You: geerbangr
  • bountyhunter
  • bountyhunter's Avatar
Re: Cleaning carbs
24 Aug 2013 04:11
#602847
geerbangr wrote: Cleaning carbs after 33 yrs of sitting inside. I picked up a KZ that's been parked since 1980. I'm sure the carbs are closed of. What should be my first step after pulling them off bike. A good long thorough soak in lacquer thinner ? Is it safe to soda blast the inside and outside of the carbs to help rid of the crud ?
I wouldn't use lacquer thinner because there are plastic parts inside.
You could get some liquid Gumout and pour it in through the gas inlet pipe and tape it off and let it sit a few days. That might soften up or dissolve some of the stuff in the internal passages.
When you tear them down. be VERY careful with the slides as the diaphragms tear easily and do not let any solvent get on the diaphragms.
  • geerbangr
Re: Cleaning carbs
24 Aug 2013 04:31
#602848
Ok so I guess the million dollar question is , can I remove ALL plastic parts so I can let the carb bodies and bowls cook in some good chemicals for a few days ?
As for the diaphragms , they can be removed yes ?
I'm hoping to salvage the majority of parts and maybe get away with only needing a handful of gaskets for the carb rebuild. I guess worst case senerio is a 100 kit for all 4 carbs :((
Hope I can run through the carbs for about 20 bucks :))
1978 KZ 1000
I go by Jason
  • martin_csr
  • martin_csr's Avatar
Re: Cleaning carbs
24 Aug 2013 08:04 - 24 Aug 2013 08:05
#602857
What bike? It may have mechanical slide carburetors, so there might not be any slide diaphragms to tear.
However, there may be plastic limiter caps over the pilot adjusting screws or something.
Last edit: 24 Aug 2013 08:05 by martin_csr.
  • geerbangr
Re: Cleaning carbs
24 Aug 2013 12:30
#602874
1978 KZ1000 A2
1978 KZ 1000
I go by Jason
  • 74ullc
  • 74ullc's Avatar
Re: Cleaning carbs
24 Aug 2013 14:26
#602886
Why have you been sitting inside for 33yrs? :silly: You found a KZ thats been parked since it was only 2 yrs old? Wow! Is it all original?
You need to keep the carb parts with the carbs they came out of. Don't mix up float valves and needles....keep all that stuff in sets! I have 4 margarine tubs numbered 1-4 and I keep everything with the carb it came out of...even screws!
Be careful with pine sol, I have heard it will stain the carbs dark grean if left in it too long!
I have soda blasted carbs with great results. Some people say not to...but I have and have had great results! I did not blast the insides of my KZ carbs since their inside was clean...but...I did blast the heck out of the inside of a 1975 DT125 carb since it was WAY bad. Rinsed the carb with very hot water to dissolve the soda and that bike runs like new!
If you do some searches there are numerous threads on cleaning cabs including the pilot circuit. Pilot circuit seems to be the biggest issue for people to get clean.
You shouldn't need to take the carbs off the holder....leave them as a rack for now. I wouldnt mess with taking apart the slide assemblys. Leave them together for now and trust that the synch was set correctly back in 1980. You might end up having to split the carbs later to replace the fuel T's between 1-2 and 3-4 but for now I would leave it.
Sounds like you haven't cleaned or messed with carbs before? Thats why I recommend leaving the rack together for now. Gain a little experience with them before going all in. I don't think KZ carbs are a good set to learn on. If you mess them up you could be screwed, many parts are not available. Do you have a lawn mower or weed eater sitting around that you can clean the carb on first to kinda get the feel for it?
Check this out also....
www.thegsresources.com/garage/docs/vm_carb_rebuild.pdf
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
  • geerbangr
Re: Cleaning carbs
24 Aug 2013 15:35
#602890
Thanks for the info 74 !! I've disassembled and cleaned a few dozen carbs in my time. Just never fooled with a set that has sat as long as these have. I'm about half afraid to open them up because they're probably filled full of crud. If they're to bad I'll boil them out in antifreeze. That's what we do to stained ,gummed up engines and pipes in the RC helicopter world.
I'm hoping the parts will clean up nicely and I can get away with some gaskets instead of 4 rebuild kits. I probably over paid for the bike when I bought it so in order as to not get scalped by the wife I'm trying to limit my funds spent on this bike.
1978 KZ 1000
I go by Jason
  • MFolks
  • MFolks's Avatar
Re: Cleaning carbs
24 Aug 2013 16:16
#602892
Carb Cleaning 101
The elements of internal combustion engines are: correct fuel/air ratio, spark at right time, adequate cylinder compression.
There are many passageways and openings to check and clean. All are important in function and when obstructed or not working properly, have subtle to radical effects on engine performance. Vacuum leaks and carburetor synchronization also effect performance and should be inspected and adjusted following the below procedures.
Warning: Remove all rubber (Neoprene) parts before you begin. These parts usually include vacuum diaphragms, needle valves, o’rings, hoses, and other parts. Spray cleaners may damage these parts. Do not disassemble individual carbs from the carb bracket.
Air & Fuel Passageways: Trace and learn individual fuel and air circuits from beginning to end. Machines can only drill straight through the cast passageways. To change direction, another angled passageway must be drilled. The union is plugged with a brass or bronze bead. Inspect and clean each passageway with spray cleaner, brushes/pipe cleaners/etc, and compressed air. Remove any discoloration and debris. Look for spray cleaner to exit from one or more passageways.
Jet Cleaning: Inspect jets by holding to light and look through them. You should see an unobstructed round hole. Clean the jets with one or more of the following: jet cleaning wires, soak solutions, carb spray cleaners and compressed air. Re-inspect jets after cleaning and install when clear of obstructions. Some main jets have paper-like gaskets. Most have metal spacers between the jet and the emulsion tube. Some screw directly into a brass emulsion tube which is machined for a 7mm wrench at its float chamber exposed base.
Inlet Fuel Valve: Inspect the needle valve & spring. Press down the tiny metal rod that protrudes from the butt or float end of the needle valve. The spring should move freely and return the rod to its location. Check the needle valve’s seat area for a groove or other wear. It should appear highly polished. Some needle valve seats are rubber and wear may not be visible. Inspect the needle valve jet seat. You can clean the jet seat with Q-tips and semi-chrome polish if necessary.
Carb Body Castings: Blow air through the atmospheric vent holes located on the dome of each float bowl chamber. Air should exit via hoses or brass nipples. Inspect the emulsion tubes and passageways (cast towers that jets thread into) for discoloration and debris. Clean interior emulsion towers with a soft bristle gun cleaning brush. Clean each Venturi (main carb bore).
Needle Jets & Jet Needles: Clean the needle jets, jet needles, and passageway or tower that needle jet screws into. Clean the emulsion tube (pipe between needle jet and main jet) (Main Jet may screw into emulsion tube). Jet needles are part of the throttle slides. See below…
Throttle Slides: There are several types of throttle slides: Mechanical linkage, vacuum, diaphragm, and cable. Disassembling the jet needle from the slide is not always required for cleaning. If you have vacuum piston type throttle slides (large diameter solid metal slide), avoid cleaning the lubrication from sides and caps. If piston type check cap vents and passageways with air. Clean if necessary and re-lube. If you have rubber vacuum throttle diaphragms, inspect for dry-rot, defects, and tears by gently stretching rubber away from center. Do this until all areas around diaphragm have been inspected. Replace any defective part as described above. Clean carb body areas around diaphragm including air passageways and air jets. Diaphragms have a locator loop or tab fabricated into their sealing edge. Observe this locator upon reassembly. Avoid pinching the diaphragm when reinstalling caps.
Fuel Screws: Fuel screws have sharp tapered ends. Carefully turn one fuel screw in while counting the turns until it seats lightly. Warning: These screws are very easily damaged if over tightened into their seats. Record amount of "turns-in" and remove the fuel screw, spring, washer, and o'ring. The fuel screw is part of the enrichment (choke) circuit...clean passageways as described above. When carbs are assembled, spray low PSI compressed air into diaphragm air vents located at intake side of carbs. Throttle slides should rise, then fall when air is removed. Lightly lube external moving linkages. Reinstall carbs and follow through with carburetor synchronization.
Throttle Cables: Lubricate cables periodically. If cables are disconnected from carbs or removed for replacement, etc . . . remember cable routing and ensure proper reinstallation routing. Avoid bread-tying, sharp bends, and pinching cables. Adjust cables so throttle grip has about 5mm of play or throttle slides or butterfly valves may not open completely (full throttle)(wide full open).
Float Bowls: Inspect float bowls for sediment, gum or varnish, crystallization, and defects. Clean all pipes, tubes, passageways, and embedded jets with cleaners and compressed air. Remove and clean the drain screw and area. Inspect bowl gasket and replace if necessary. Clean and inspect overflow pipes and tubes, look for vertical cracks.
Floats: There are several types of float materials: plastic, brass, black composite, tin, and others. Handle floats carefully. Avoid bending, twisting, denting, or other means of mishandling. Most floats are adjustable by bending a small metal tab near the float axle end. Do not change the float adjuster tab unless tuning fuel service levels. Clean metal floats by soaking or by spraying cleaner and wiping clean. Other material type floats may require replacement if cleaning is necessary. Inspect the needle valve (float valve) and seat. Check needle valve’s spring loaded pin. It should depress and return smoothly and without resistance. Check the needle valve’s tip for a worn groove. Replace needle valve and seat if either symptom exists. These parts wear together and must be replaced as a set.
Synchronization: This is a fine adjustment performed usually and preferably with the carbs installed and the engine running. The unusual part is performed with gauged wire with the carbs on the work bench. Carburetor synchronizing balances Venturi vacuum at the exhaust side of each carburetor, resulting with smooth idling and optimized performance at all throttle openings. Synchronization is checked using a set of gauges which are either air vacuum type or liquid mercury type. The gauges are connected to vacuum ports on the intake manifolds via nipple tubes or if sealed with screws, sync gauge adapters will be needed. With the engine running at temperature, and with a fan or means of forced convection aimed onto the engine, the carbs fuel screws and idle are adjusted, then the synchronization is adjusted via adjustment screws on the carbs. A reserve fuel tank is recommended for convenience of accessing carbs during this procedure. See gauge instructions and repair manuals for detailed use of synchronization gauges.
Notes: While carbs are apart, record the jet sizes. Look for a very small number imprinted on the body of the jets. Verify that numbers are the same for all jets on models with in-line cylinders. A few transverse-4 models and V-engines, the inner and outer carbs use some different size jets and it's important to not mix them up. If you have dial or veneer calipers, measure and record float heights. Perform measurements with floats just touching needle valves, though not depressing the needle valve rods. Replace fuel and vacuum hoses. Be sure to use fuel rated hose for fuel. Install or replace in-line fuel filters. It’s a good time to remove and clean interior petcock fuel filters. Inspect carb manifolds for dry-rotting, inspect all clamps and air ducts. Inspect, clean, lube, and/or replace air filter(s).
  • MFolks
  • MFolks's Avatar
Re: Cleaning carbs
24 Aug 2013 16:17
#602894
Carb Cleaning 102
Most carburetor problems seem to come after the motorcycle was stored or not started for a while. If it won't start or only runs with the choke lever pulled out, you have one or more jets obstructed by gummed or varnished fuel. Notice the enrichening lever...most of the motorcycle carbs have enrichening passages inside the carburetor that WHEN THE THROTTLE IS CLOSED, provide the rich air/fuel mixture to start the engine. If you open the throttle any at all it cuts this enrichening out of the system. So if you are having trouble starting and everything looks ok, see if closing the throttle helps. This does not apply to carbs with a butterfly choke.
To access the jets you will have to take the carbs off the engine. A service manual will be very helpful here for specifications, images of the carburetor, and procedures. Take a float bowl off and remove the jets. Sometimes removing the jets can be difficult because the fuel has gummed or varnished over the parts. If so, clear as much of the gum out as possible. Use carb cleaner and compressed air to aid removal. Before soaking carbs in a dip tank or powerful cleaner, look for rubber seals, O'rings, and other parts that may be damaged by the cleaners. Remove any rubber parts prior to cleaning. Look closely, sometimes these parts are hard to see. If they are there and you can't get them, you will have to clean the carb body carefully by hand and not soak it.
Before you remove the fuel/air screw, gently turn it in until it seats. Count and record the number of "turns in." After cleaning and when you replace it, set it at this setting. Most carbs have a rubber o-ring and steel washer under the fuel/air screw spring. Look for them and remove them with a piece of wire or suitable fabricated tool BEFORE you spray carb cleaner in there. The fuel/air screw may be covered by a tamper cap or plug. You will have to remove this plug to access it. Upon reassembly and after cleaning, a base setting for the fuel/air screws of 1.25 turns out is good to start if you don't have the factory specs or forgot to record the turns out earlier. When the engine is warm, turn the screw in until the engine stumbles, then out until it stumbles, and leave it at half way in between. Adjust the idle with the throttle stop screw as needed.
You will need to remove the main jet and the needle jet. The main jet is usually larger and screwed onto the lower end of the needle jet, locking it into the emulsion tower and carb body. Remove the main jet and tap out the needle jet. Do this very carefully. It is soft brass and may break or damage very easily. Sometimes the needle jet will have an O-ring. Remove the O-ring and soak both main jet and needle jet in carb cleaner. Upon reassembly, there may be a locator pin in the emulsion tower/carb body that fits in a grove on the needle jet. Make sure they align properly.
You will need to remove the pilot jet. Pilot jets may be located similar as the main jet, covered by a rubber plug, deep inside an emulsion tower, or other. Be careful not to strip or break the small pilot jet when you try to remove it. It may be necessary to grind the end of a small screwdriver to fit the jet just right. Even after soaking, the jet may still be plugged. Use a small "E" guitar string and push it through the jet. (A wire strand out of a wire brush may work. The wire brush should measure about .013" in diameter.) The smallest jet drill you can get is #80, which has a diameter of .0135". You can use the wire and not enlarge the hole, at least not by much. Yes, some manuals say not to insert any wire jet cleaning tools into the jets. However, Honda and other manufacturers produce them as special tools for the dealer technicians.
Use compressed air with spray cleaner and the wire to clean jets. Spray carb cleaner into the carb passages, and then follow with compressed air. Watch for cleaner to exit from other passage ways and openings, and ensure that those small idle passages are clear. The smallest tubes, passageways, and openings are critical to the operation of the carburetor. EVERY PINHOLE IS IMPORTANT. Make certain that your see and hear air and cleaner pass freely through every opening. Wear goggles and don't get so close that you get carb spray in your eyes.
Sometimes the pins or rods that hold the floats can be gummed. Spray a bit of carb cleaner and let it set awhile. Repeat and try to gently move the float. Eventually, the pin will loosen enough so that you can drive out the pin with a very small punch. If necessary, tap on the punch very gently with the handle of a small screwdriver or similar tool. Penetrating oil also works good to free up gummed float pins and stuck throttle slides. If the slides have a rubber diaphragm on them, spray carb cleaner on a rag and wipe the slide clean. Do not get carb cleaner on the rubber diaphragms. It will ruin them. While you have the Diaphragm out, inspect it for holes. If you have an engine that has good compression and starts well, but just has no power and revs up ever so slowly, check that rubber diaphragm. It may have a hole or tear. The throttle slide will not rise if it is damaged.
When you put the float valve or needle valve back in place, put a drop of light oil on it so it will move freely in its seat and not stick before the gas first starts to fill the bowl.
Don't clean the outside of constant velocity (CV) carbs with spray carb cleaner unless you are sure they are not the rubber diaphragm type. Carb cleaner will ruin the rubber. There is a piston type of CV carburetor, but it's still not a good idea to use the spray because of rubber float bowl gaskets (O'rings).
If you turn on the fuel petcock and gas pours out the overflow tubes, tap lightly on the carb body with a suitable tool. That will vibrate the float valves loose. Same thing if there is dirt holding the valves open. If it doesn't work you need a new float valve & seat. The tips of the float valves can be steel or rubber. Tips with a groove worn in them should be replaced. The float pin springs often become gummed by fuel and cause the pins to stick. Test with your finger. They should be free moving - no resistance. Replace all if you feel any sticking. If they first stuck, but you worked them free, try and use them. They may fail when gasoline gets into the spring again.
Floats control the fuel level in the float bowls. Adjustable tangs on the floats rest on the float valve pins. When level is low, the float lowers and the valve follows. More fuel enters the bowl. Similarly, shutting fuel flow off when it replenishes supply. If the tang is metal, you can adjust the float level by bending the tang up or down. If it is plastic, it is non-adjustable. Float levels are different for each bike and are found in the bikes shop manual. If you don't have the float setting and can't find it anywhere, set it so the fuel level is a bit below the top of the float bowl. Make sure no gas comes out of the float overflow tubes or hoses. The float overflow tube is at the bottom or side of each float bowl. There are many styles of floats: copper, brass, bronze, plastic, urethane, tin, cork, and maybe other materials. Brass and plastic are the most common.
If the rubber ducts that connect the carb and air cleaner housing are hard and dry-rotted, you should replace them. Replace rubber intake manifolds if necessary, too.
On the side of some carbs is another diaphragm that temporarily closes the pilot or slow speed jet air passage when the throttle is closed. This richens the fuel mixture to reduce backfiring when coming to a stop. Check the diaphragm for holes and tears.
At the bottom of some carbs is an accelerator pump to pump extra fuel when the throttle is opened. The pump is attached or connected to one float bowl. Check the pump's diaphragm for holes or tears. A rubber coating called "Plasti-Dip" has been used to fix diaphragms. I have never used it but I hear it works. Get it from NAPA part #765-2527.
Adjustments that you can make from outside the carburetor:
1) Synchronizer screws balance the carburetors for smooth performance and idling. 2) Idle screw (throttle stop screw) adjusts the speed of the idle. 3) The idle fuel/air screw adjusts the idle mixture. This is only at idle and does not effect anything above idle. Another method to adjust it: turn the fuel/air screw in and out until you get the highest idle speed. Then lower the idle speed with the idle screw and do it again until you get the best idle. The air screw can be located in a variety of places on the carb. If you have a 1980 or newer machine, it may have a cover over it to keep you from messing with it. You will have to drill it and then pry it out using the hole you made. It may be illegal for you to do this, depending on where you live.
If you can't get it to idle, or rather the idle stays real high then drops off and dies, check for an air leak. Spray starting fluid, WD40, brake cleaner, carb cleaner, etc... on the manifold, carbs, air box, vacuum hoses, and petcock to see if the revs change. If they do, you have a leak. If your valve clearances are too tight, it will also effect the idle.
You can make your air/fuel mixture a bit richer or leaner by moving the carburetor needle clip up or down. Move the clip down a notch to raise the needle, to richen the mixture. Move the clip up to lower the needle, to lean out the mixture. The needle is located in the throttle slide.
You should always turn the fuel off. If you don't and the carb inlet needle fails, it will fill your crankcase full of gas. If you have a four stroke, it thins out the gas and parts start to weld together. If you have a two stroke, it will fill up the crankcase with fuel and can cause it to hydraulically lock. Many newer bikes have a fuel petcock with a diaphragm that only lets fuel into the carb if the engine is running. It operates on vacuum. Normally you have three settings. On, Reserve, and Prime. Prime bypasses the diaphragm to let fuel into the float bowls after service or storage, etc.
  • geerbangr
Re: Cleaning carbs
24 Aug 2013 16:58
#602897
MFolks !!! That's what I'm talking about !! That's some serious carb information !! Thanks for that !!!!!!
1978 KZ 1000
I go by Jason
  • bountyhunter
Re: Cleaning carbs
24 Aug 2013 17:14
#602899
geerbangr wrote: As for the diaphragms , they can be removed yes ?
Yes, but be very careful removing the slides/diaphragms as they stick and are easily torn.
