Engine Not firing, suspected carb issue
- emptypond
the black rotor in the picture.
I have verified the spark on all cylinders, but possibly, I'm timing it wrong. I have tried timing it different ways both statically, as the bike doesn't stay running long enough for me to use a timing light. I tried timing 1-4 to the "T" mark, without advancing the assembly and I tried timing to the "F" mark, by hand moving the rotor to complete the spark. Since I've been playing with that all day, checking and re-checking, I've thrown the battery on the tender for the evening (it's a brand new battery) and I can't say for sure if the 1-4 at "T" works better than hand advancing when the mark is on "F". Hopefully that makes sense... I appreciate all your input!
81 kz750 frame, with an 83 kz750 engine.
- Motor Head
- Thank you received: 391
Even when cranking, you should be able to use your timing light to verify the base setting.
- koolaid_kid
- Thank you received: 99
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
- emptypond
My issue is this now- I get spark visually on ALL 4 cylinders, with the wire and plugs out and I'm physically looking at the plug firing. When I put them back in, and hook up the test light, the light only works on cylinder #2, which is the only cylinder that was working before. I'm thinking maybe this is a ground issue? It's not the coils, as I switched them around and the same thing happened, and all four spark plugs spark when outside the bike. I have all new wires, all new plugs, and a DYNA S ignition. What could this be???
- koolaid_kid
1983 GPz 750
- emptypond
- koolaid_kid
1983 GPz 750
- emptypond
- Motor Head
Also what Voltage is measured across the battery terminals, then across the coil primary terminals? Same? Or is there voltage drop?
- emptypond
- Motor Head
- koolaid_kid
Please do not double post. You will get conflicting messages. We will continue helping you here.emptypond wrote: It's odd, because one cylinder is sparking and the light works on that one, and only that one. could it be it's not picking up the strength of the spark? I should probably move this thread to the electrical section too...
1983 GPz 750
