- Thank you received: 64
Trouble starting my KZ750 when cold
- undiablo
15 Jul 2013 20:08 #596656
by undiablo
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
Replied by undiablo on topic Trouble starting my KZ750 when cold
Try to use a 5w40 oil if you have extreme cold weather. The difference was outstanding in my case.
- davew9wrl
16 Jul 2013 15:39 #596777
by davew9wrl
Replied by davew9wrl on topic Trouble starting my KZ750 when cold
No sure what Bump Starting means. Does it push start ok, but not with the electric starter is this what you mean?
I have found that if the starting is dragging it will not produce the correct rotation speed and the bike can be hard to start, when you push start the bike you get a much faster engine rotation and it will start right up. I am guessing this bike does not have a kick starter?
I had a KZ 650 a few years back that would start right up with the kick starter, but was hard to start with the electric stater, answer was to rebuild the stater as it was dragging.
- astark
17 Jul 2013 03:09 #596890
by astark
1980 KZ750H LTD
Replied by astark on topic Trouble starting my KZ750 when cold
Bump starting is the same as push starting. I think you're right about it being the starter. Often the starter will spin, then make a grinding noise, then sometimes will fire the engine up, sometimes not. Could this be the starter clutch? or the starter itself? It still fires right up when the bike is warmed up though
1980 KZ750H LTD
- Thank you received: 2829
17 Jul 2013 08:52 #596900
by 650ed
Replied by 650ed on topic Trouble starting my KZ750 when cold
Sounds like the classic starter clutch failure symptoms. If you decide to replace it there are some good links available on the process. Let me know if you want them. Ed
- astark
18 Jul 2013 01:58 #597056
by astark
1980 KZ750H LTD
Those links would be great. I'm gonna consult my mechanic friend and see what he thinks before i start tearing into it.
1980 KZ750H LTD
- astark
18 Jul 2013 02:10 #597058
by astark
1980 KZ750H LTD
The only thing that makes me think it might not be the starter clutch is that it fires right up when the bike has been warmed up.
1980 KZ750H LTD
