Trouble starting my KZ750 when cold
- astark
1980 KZ750H LTD
- Thank you received: 2829
- Del_Herring
- Thank you received: 29
Don't touch the throttle when starting the bike. Doing that is counterproductive to the enrichment process. Does your bike have the stock air box & filter? Ed
I know that's true on the KZ1000's and others that use that style carb. But The Keihin CV carbs use a true choke, not the enrichener circuit, so opening the throttle shouldn't counteract the choke. Normally with a true choke you want choke at full, and throttle open when starting. Don't see why it would be any different here.
1983 KZ750-N2 Spectre
- astark
1980 KZ750H LTD
- astark
1980 KZ750H LTD
- Cynjut
- Thank you received: 26
Have you checked the tops of your carbs for leaks in the membranes on the throat slider?
Check the plugs for burn color. Tan is good, white is lean, black is rich, oily is oil.
There are lots of things that all need to be right for your bike to start when cold. If everything works once the bike is warmed up and you're happy with the performance and response of the bike, chances are that the specific enrichment/choke circuit is where your problem is.
On the other hand, I've heard horror stories about bad rectifiers, resistor plugs with resistor caps, bad ECUs, and a dozen other 'non carb' issues causing similar problems. Make sure your battery is in good shape, that you're getting good spark, and everything else that needs to be working before you get boresighted on the carbs. Taking 10 minutes to check the rest of this stuff might end up saving you hours working on something that's already working.
This, by the way, is the voice of experience nattering away. I wasted three weeks trying to adjust a set of carbs on a bike with a leaky vacuum membrane in the fuel petcock.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
- astark
1980 KZ750H LTD
- Spectre1982
- Thank you received: 9
1982 Kawasaki KZ750 Spectre
1978 Kawasaki KZ200
1985 Yamaha XV1000 Virago
(Avatar picture is from Alleycatscustoms.com)
- ThatGPzGuy
- Thank you received: 385
Good luck,
Jim
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- NovaNewfie
How old are your coils/wires?
Have you checked the voltage to your coils?
1979 KZ1000E-1 ST
- undiablo
- Thank you received: 64
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
- astark
1980 KZ750H LTD
