- Thank you received: 1
How do I adjust floats on a 1981 kz750 LTD 4-cyl?
- QNman
14 Jun 2013 23:00 - 14 Jun 2013 23:02 #592350
by QNman
How do I adjust floats on a 1981 kz750 LTD 4-cyl? was created by QNman
I know the floats need adjusting because the carbs are rebuilt... but how do you do it? The instructions I've seen in my Clymer basically state you have to assemble, then check, then disassemble, adjust, and reassemble, start all over. Is there an easier way?
Last edit: 14 Jun 2013 23:02 by QNman.
- Thank you received: 2829
14 Jun 2013 23:08 #592351
by 650ed
Replied by 650ed on topic How do I adjust floats on a 1981 kz750 LTD 4-cyl?
Start by doing the clear tube test (see link below) to determine if any adjustment is required. Ed
kzrider.com/forum/2-engine/580335-homead...at-level-tool#580344
- QNman
16 Jun 2013 13:41 #592546
by QNman
Replied by QNman on topic How do I adjust floats on a 1981 kz750 LTD 4-cyl?
The carbs are already off the bike... do they need to be mounted on the bike to test?
16 Jun 2013 13:59 #592550
by 650ed
No, they don't need to be on the bike. Some folks have screwed an old set of carb holders to a board and installed their carbs on the board, clamped it in a vise or Work-mate, and leveled it up, and then performed the clear tube test. This made it easier to get to the floats to make any necessary adjustments. Ed
The following user(s) said Thank You: QNman
- KZB2 650
- Thank you received: 265
16 Jun 2013 14:02 #592551
by KZB2 650
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Replied by KZB2 650 on topic How do I adjust floats on a 1981 kz750 LTD 4-cyl?
I just did mine on the bench just make sure your holding then nice and straight both ways when checking.
Was a pain to me too, lotta draining and re checking but worked out. All mine were right at the top of the bowl (a little high)so I had to bend the tab a little on all 4. Got em all pretty good the first time (bottom fourth of the bowl) except for one which I had to do twice.
I appreciate 650ed, Patton etc etc for pushing this, checking this because it was something I put off for a long time.
1978 KZ650 b-2
