Homeade float level tool?
  • Matteson
  • Matteson's Avatar Topic Author
03 Apr 2013 01:02
#580335
I went and got a grease fitting but the threads were to large. Maybe I can find a smaller one. Does anybody have any other suggestions as to what would be easy to get my hands on to make something to get my float levels right?
KZ 900-a4
Re: Homeade float level tool?
03 Apr 2013 01:09
#580337
Float tang is adjusted to achieve desired fuel level as shown by the clear tube test.
Good Fortune! :)
  • Matteson
03 Apr 2013 01:15
#580340
I know,and I need to pull the drain screw and put a banjo type screw with a nipple on it into the hole with a tube on it. Can't find that kind of screw yet. Been looking. The best I could find was a grease fitting. But it was too large. So before I go back all that way maybe somebody knows exactly what I'll need beforehand.I have 26mm vm's.
KZ 900-a4
03 Apr 2013 01:23
#580344
The "special tool" is not required.
Just use tubing size that fits snugly or "self-threads" into the drain hole.
Slight minimal seepage won't invalidate the test.
Good Fortune! :)
  • wireman
  • wireman's Avatar
03 Apr 2013 01:29 - 03 Apr 2013 01:30
#580345
Heres the hose with correct fitting from z1 enterprises
Attachment floattool.jpg not found
$9.00 and change plus shipping :)
Last edit: 03 Apr 2013 01:30 by wireman.
  • Matteson
04 Apr 2013 17:20
#580566
Thanks Patton got a 2mm clear hose from pet store in the aquarium section. Fit snug with no leaks as you said. #1 was too high as I figured. While I was in there the main jet was very loose and about to fall out. Maybe this is the culprit to the sputter over half throttle? We will soon find out...
KZ 900-a4
