Jetting for Velocity Stacks
- Tcarsten
30 May 2013 19:24
Ok so I rebuilt my 82 KZ750 twin and took out the air box and out in Velocity Stacks. I ordered a jet kit from 6 sigma. Installed there kit and the bike is running idling and has throttle from idle to 1/4 after that the bike dies.
The main jets they gave me are 130 and 136 both jets have the same response. I also have 132.5, 135, and 137.5 main jets. I have one spacer under the needle raising it, I have tried 2 but get no change.
any help would be very appreciated hopefully i didn't miss anything.
Thanks
Thanks
Re: Jetting for Velocity Stacks
30 May 2013 19:49
Good luck tuning those CV carbs with no airbox. You may want to read the article in the link below. Pay special attention to the last 3 paragraphs. Ed
kzrider.com/forum/3-carburetor/585949-po...-a-free-lunch#585949
- DoubleDub
30 May 2013 20:19 - 30 May 2013 20:19
You can try pulling the choke to see if it makes past 1/4 throttle better or worse. If better, you need bigger main jet, if worse or no change, you likely need smaller main jet.
Edit - although I tend to agree with Ed on the CV carbs.
Last edit: 30 May 2013 20:19 by DoubleDub.
- Tcarsten
30 May 2013 20:58
Yea I have heard all about CV carbs
"good luck kid your gonna need it"
"have fun with that you will be jetting for the rest of your life"
I think im really close i can get it past 1/4 with out the choke just cant do it fast.
I was told to cut the springs in the slides to get quicker throttle response. Is this true?
- crh
- Banned
30 May 2013 21:04
You can tune those carbs to work with stacks as long as you have a jet kit it's not that bad to do. I've done dozens of them on Suzuki, Kaw & Yamaha. The gain isn't going to be anthing to write home about but IT IS WORKABLE.
I haven't used or even heard of that particular jet kit. Do they include new needles & are they adjustable with clip grooves in them?
If yes, lift them a full clip position [clip down to next lower groove] then see how it responds.
Every DynoJet, K&N & Factory Jet kit I've installed has worked quite well.
- Tcarsten
30 May 2013 22:23
Yea the kit did not come with an adjustable needle just spacers to go under the needle. They say they will help me with what ever I need to get it running to where I am happy, but they have sent me one email to my 5 in the past 3 days, that is why I turned to everybody here to see if I could get some help. Im gonna trey another spacer under the needle
- Tcarsten
31 May 2013 00:27
If I was to buy the Mikuni VM carbs what size or how do I measure for them?
- crh
- Banned
31 May 2013 07:04 - 31 May 2013 07:05
I would say their jet kit isn't worth buying. The needle is the most critical part of the kit. It is the very reason you buy a kit. Contact DynoJet and see if they make a kit for that model. Ask them specifically if their kit includes new needles.
34mm VM or RS carburetors would be what I would use if I was swapping out carbs completely. I don't know and highly doubt if Sudco or anyone else has a read to bolt on set of carbs for that bike.
You might look into other kits if any are available. You might see if Holeshot.com had anything for it. If nothing is available the best move would be to bolt the airbox back on it and enjoy your riding season....
Last edit: 31 May 2013 07:05 by crh.
- Tcarsten
22 Jun 2013 11:28
Just an update Bike is running great. I sent back the shitty 6Sigma jet kit, DO NOT EVER BUY from this guy he is an asshole and not helpful in fixing problems. Anyway I ended up using a 125 main jet with a spacer under the needle. I am still looking for adjustable needles not having any luck. I have been riding it finally for a couple of days now and am excited its back on the road, I just need to keep the ash out of the carbs from all the wild fires around me here in CO.
Thank you to anybody who helped and gave suggestions
Here is a picture
Here is a picture
Attachment IMG_1593.jpg not found
