- Thank you received: 198
Gas running out of pod filter
- peter1958
- Banned
29 Apr 2013 17:16 #584696
by peter1958
Replied by peter1958 on topic Gas running out of pod filter
Thanks . The parts are in stock in garage . I was stumped because the tank is ultra clean. The fuel tap is the same and the needle seat is as clean as a whistle.
- peter1958
- Banned
29 Apr 2013 17:17 #584697
by peter1958
I had rebuilt the set of carbs awhile back
- peter1958
- Banned
29 Apr 2013 17:23 #584700
by peter1958
do I need to get a magnafigy glass out to look at the petcock diapfragm?
- Thank you received: 2829
29 Apr 2013 17:29 #584703
by 650ed
Replied by 650ed on topic Gas running out of pod filter
Please don't be offended, but you're not leaving the petcock on "Prime" are you? (again, I'm not being a smart a$$) Ed
- peter1958
- Banned
29 Apr 2013 17:48 - 29 Apr 2013 17:50 #584705
by peter1958
No Not on prime Ed and hell we are trying to figure this out so not offended. Ive done some dumb chit so ya never know.
Last edit: 29 Apr 2013 17:50 by peter1958.
- jonarmstrong
- Thank you received: 13
29 Apr 2013 23:25 - 29 Apr 2013 23:29 #584789
by jonarmstrong
82 Kz1000 gpz1100 cams dyna ignition kerker k&n
Replied by jonarmstrong on topic Gas running out of pod filter
Made some plugs out of brass rod on a lathe. Work great
Last edit: 29 Apr 2013 23:29 by jonarmstrong.
- baldy110
- Thank you received: 512
29 Apr 2013 23:32 #584794
by baldy110
Replied by baldy110 on topic Gas running out of pod filter
Even if the petcock is leaking the fuel should not get past the needle, seat and float. Like Patton said you CANNOT fix a leaking needle and seat by fixing the petcock.
