Guide or rule of thumb for pods / jet size?
- jonarmstrong
Re: Guide or rule of thumb for pods / jet size?
18 Apr 2013 10:47
I don't have a pc. I'm using a smart phone for internet service so im a little limited on what I can do. Thanks tho!
82 Kz1000 gpz1100 cams dyna ignition kerker k&n
- baldy110
18 Apr 2013 13:39donthaveakawman wrote: from what I understand the jet kits make it easy to foul out a plug for example if you give it a big rev and then slow down the spark plugs will get coated in gas and you will be dead in the water for a bit. other upgrades are necessary with a jet kit such as the ignition and exhaust.
So what your saying is, when you get off the gas with a jet kit installed the igntion stops firing the spark plugs? Where in the world do you come up with this stuff?
