Guide or rule of thumb for pods / jet size?
- magruder13
1982 Honda XL125S
1972 Yamaha TX750 (CB750 engine)
1976 Kawasaki KZ400
- Thank you received: 2829
www.mediafire.com/?7ttgomzmmjz
At the link click at the arrow in pic below:
Attachment 00000_2013-04-16.jpg not found
- donthaveakawman
- Visitor
- magruder13
650ed wrote: You need to add the year and model of your motorcycle to your signature line. Does the bike already have pods on it, or are you about to put them on and learn all about carbs in the process? If you want some interesting reading on the subject, go to the following link and read about some extensive testing and tuning.
Signature changed, sorry about that, never got around to it. The bike in question is the 440, and it does already have pods on it. I got it in pretty bad shape from a guy who knows less about bikes than I do. I want to verify that he's not a complete idiot and did change the jets / buy a new kit to make sure it's done right.
@ Donthaveakawman, I can handle quite a bit more than this 440, regardless of what you put in it. I learned to ride before I learned to walk.
1982 Honda XL125S
1976 Kawasaki KZ400
- donthaveakawman
- Visitor
- bountyhunter
- Thank you received: 337
The rule I have read is for pods, add one or two on the pilot jet and MAYBE go up one on the main. If you add low restriction pipes, add one or two on the mains. It all depends on how the overall airflow of the system is going.magruder13 wrote: Hey all, I was wondering if there was a guide or a rule of thumb for using pods and the corresponding jet size. I'm VERY new to carbs, I only barely understand how they work. I've been struggling to find a good place to read up on them, if anyone has a link I would love to read more. Also, where does everyone buy their carb repair kits / jet kits / parts from? Thanks!
That said, it will never run right again.
- Old Man Rock
- Thank you received: 225
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- jonarmstrong
- Thank you received: 13
82 Kz1000 gpz1100 cams dyna ignition kerker k&n
jonarmstrong wrote: Old Man Rock, Where did this exert come from? It's too blurry to be able to read it all
If your PC is similar to mine you can hold down the Ctrl key while you hit the + key and the image will enlarge each time you hit +. I tried this on OMR's posting and the test is pretty clear even when magnified. (Hit Ctrl - or Ctrl 0 to shrink it back to normal size). Ed
- magruder13
@ donthaveakawaman As far as I can tell, the exhaust is stock but it sounds like he removed the baffles, its really quite loud!
@ bountyhunter I would like to run the stock airbox but I don't have one (PO was an idiot) and I can't find one online for anything short of a small fortune.
@OldManRock Great post, really informative, thanks a bunch, just one more question, where do you buy jets from? Are they a universal part or are they Kawa/Honda/Yamaha specific?
@ 650ED I think the carbs are stock, not 100% sure.
1982 Honda XL125S
1976 Kawasaki KZ400
- donthaveakawman
- Visitor
