yup...small stumble.
- CDNTX650
Ill update again once its warm enough to rip er.
- havakaw
- Thank you received: 27
'80 KZ 750 LTD-H
'82 KZ 1100 A-2 Shafty (ex-bagger)
- CDNTX650
Took it for a ride, idles a lot better. seems to really like 1400rpm so thats generally where i leave it. Starts easier. Still a bit of stumble, but it seems alot better than it was. Seems like they dont like agressive throttle where im feeling that stumble. I can roll through it. But its running great and as far as im concerned as good as it's probably gonna get till i can put a Boyer or Dyna in it. Been through the carbies a million times and did the WG coil mod. All new manifolds and box boots. Plus new coils/caps/condensers. Points are coming.
Next winter it gets some new paint and a from scratch wiring harness. Probably check my lash too while its apart.
- CDNTX650
- Motor Head
- Thank you received: 391
I'm sure you checked the needle clip position on the jet needles as well?
Air jets in the Air Horn/ bellmouth clean UN-obstructed?
vacuum sync performed?
Then of course there is always the mechanical, hows the compression balance?
- CDNTX650
- Thank you received: 2829
- CDNTX650
- Jrbrownie00
- Thank you received: 9
82' kz750 ltd.
- CDNTX650
- Thank you received: 2098
If carb has a side-located pilot air screw, turning the screw on carb #1 should produce a change in idle rpm. But if not, there's usually something still wrong inside the carb (likely an imperfect pilot circuit that's incapable of providing the optimal air/fuel mixture, for whatever reason).CDNTX650 wrote: ...Stumble is still there...Plugs are tan except plug one. fouled...might as well double check the ole LASH....
Would also re-examine condition of the pointed end of the adjustment screw.
That's a good idea about re-checking the valve clearances.
- CDNTX650
