Going rate on 29s
10 Apr 2013 06:23 #581555 by b200driver
Going rate on 29s was created by b200driver
Old newbie here. I am thinking about getting my 900 back on the road. It was parked due to kids and other responsibilities. I fooled with these bikes quite a bit back in the day, and will need to do a refresh on the engine, though it runs fine. I used to have several sets of 29 and 33 mikunis around. The 29's were always best for a street bike IMO. It appears that I have sold all of that stuff :(
I was looking at Ebay and just about died seeing the prices. So the question is this: What is the going rate for a rack of 29's?
10 Apr 2013 08:35 #581564 by Powerstroke_fan
Replied by Powerstroke_fan on topic Going rate on 29s
It all depends on if they are dirty or clean and ready to rock. But either way there really salty anymore.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
10 Apr 2013 09:56 #581575 by Mcdroid
Replied by Mcdroid on topic Going rate on 29s
You should expect to pay (for a decent rebuilt set) somewhere north of US$600...
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
10 Apr 2013 10:17 #581580 by zukdave
Replied by zukdave on topic Going rate on 29s
I've been offer'd enough for mine to
buy a new set of flat slide's.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
10 Apr 2013 12:54 #581616 by baldy110
Replied by baldy110 on topic Going rate on 29s
  • 4TheKZ1000
  • Visitor
10 Apr 2013 13:15 - 10 Apr 2013 13:26 #581621 by 4TheKZ1000
Replied by 4TheKZ1000 on topic Going rate on 29s
I sold my set of 29's for $700 on ebay and purchased a brand new set of RS 34's form Orient Express for $615.00
So I made $85.00 and got a set of RS34's to boot...... :woohoo:
They go from $500 to $800.00 based on condition. I say $800 due to sale on Flea Bay....link below.
motors.completed.shop.ebay.com/i.html?LH...asaki&_kw=kz&_sop=10
Last edit: 10 Apr 2013 13:26 by 4TheKZ1000.
10 Apr 2013 13:24 #581623 by Matteson
Replied by Matteson on topic Going rate on 29s
what about boring your standard set? I have read the pro's about that. Not heard much con stuff. And it appears to be cheaper.
KZ 900-a4
  • wireman
10 Apr 2013 14:09 #581632 by wireman
Replied by wireman on topic Going rate on 29s
Unless youre a nostalgia freak(guilty as charged :laugh: )Id suggest either a set of 79-80 28mm pumpers or a set of 29 cr specials.
You might pm OldmanRock/OMR hes the cr special sales rep on here! :laugh:
  • slayer61
  • KZR FLAG RELAY CARRIER #62
10 Apr 2013 16:37 #581661 by slayer61
Replied by slayer61 on topic Going rate on 29s
Those 29's are quite popular it seems. Even I traded a KZ250 for a set in the early 80's!
10 Apr 2013 17:31 #581672 by 531blackbanshee
Replied by 531blackbanshee on topic Going rate on 29s
Matteson wrote: what about boring your standard set? I have read the pro's about that. Not heard much con stuff. And it appears to be cheaper.
check out zed1015's build thread on the zephyr framed streetfighter.he just bored a set of 26mm's out to 29 mm.he said the 26's were thicker in a key area than the 28's.
10 Apr 2013 19:18 #581691 by zed1015
Replied by zed1015 on topic Going rate on 29s
I bored the 26's out to 29.5mm,could have pushed them to 30mm but it's risky as the bottom of the boot groove measures 32mm so things start to get a bit thin at that point and there's probably no gain in going that far anyway.
The 28's are a different casting and fractionally thinner in the boot mount area so 29mm is max really unless you have a stack of spare bodies to play russian roulette with.
10 Apr 2013 21:49 #581712 by b200driver
Replied by b200driver on topic Going rate on 29s
zed1015 wrote: I bored the 26's out to 29.5mm,could have pushed them to 30mm but it's risky as the bottom of the boot groove measures 32mm so things start to get a bit thin at that point and there's probably no gain in going that far anyway.
Hmm, there is an interesting idea. I used to have about a wheelbarrow full of those 26's. All gone now. I plan on using the stock airbox, so no CR's or flattys here. My bike is 99% stock right now (Kawasaki by Kerker 4-1) everything else is stock. Even the points, which will be going away I suppose. I may do a little resto-mod work, but I hate to hack it up too much. There are plenty of butchered KZ's out there, but not so many stock ones. The compressions are getting a little uneven so it is time for a refresh. I have a set of nice 78 Z1R rotors set aside for it. I need to get a RH caliper I think. I have been accumulating parts for a while. I have a 1015 cylinder block here so I can do 1075.
