Going rate on 29s
- b200driver
I was looking at Ebay and just about died seeing the prices. So the question is this: What is the going rate for a rack of 29's?
- Powerstroke_fan
- Thank you received: 83
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
- Mcdroid
- Gone Kwackers
- Thank you received: 319
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- zukdave
- Thank you received: 229
buy a new set of flat slide's.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
- baldy110
- Thank you received: 512
- 4TheKZ1000
- Visitor
So I made $85.00 and got a set of RS34's to boot...... :woohoo:
They go from $500 to $800.00 based on condition. I say $800 due to sale on Flea Bay....link below.
motors.completed.shop.ebay.com/i.html?LH...asaki&_kw=kz&_sop=10
- Matteson
- Thank you received: 6
KZ 900-a4
- wireman
- Thank you received: 299
You might pm OldmanRock/OMR hes the cr special sales rep on here! :laugh:
- slayer61
- KZR FLAG RELAY CARRIER #62
- Thank you received: 797
Matteson wrote: what about boring your standard set? I have read the pro's about that. Not heard much con stuff. And it appears to be cheaper.
check out zed1015's build thread on the zephyr framed streetfighter.he just bored a set of 26mm's out to 29 mm.he said the 26's were thicker in a key area than the 28's.
- zed1015
- Thank you received: 1581
The 28's are a different casting and fractionally thinner in the boot mount area so 29mm is max really unless you have a stack of spare bodies to play russian roulette with.
- b200driver
zed1015 wrote: I bored the 26's out to 29.5mm,could have pushed them to 30mm but it's risky as the bottom of the boot groove measures 32mm so things start to get a bit thin at that point and there's probably no gain in going that far anyway.
Hmm, there is an interesting idea. I used to have about a wheelbarrow full of those 26's. All gone now. I plan on using the stock airbox, so no CR's or flattys here. My bike is 99% stock right now (Kawasaki by Kerker 4-1) everything else is stock. Even the points, which will be going away I suppose. I may do a little resto-mod work, but I hate to hack it up too much. There are plenty of butchered KZ's out there, but not so many stock ones. The compressions are getting a little uneven so it is time for a refresh. I have a set of nice 78 Z1R rotors set aside for it. I need to get a RH caliper I think. I have been accumulating parts for a while. I have a 1015 cylinder block here so I can do 1075.
