- Thank you received: 13
Jetting Help
- Roadflyer
That will make everything a bit leaner, you might have to go to a bigger main to compensate for top end mixture.
1979 kz1000 shaftie rebuild project
1045 wiseco 10.25-1 pistons
Kenny Harmon 380 lift cams
- Thank you received: 2829
- slayer61
- KZR FLAG RELAY CARRIER #62
- slayer61
- gd4now
- Denco where did you go?
- Thank you received: 445
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- treitz
Guess it's time to jet it up and try to find that sweet spot I've been looking for all this time.
1979 KZ400 - 2-1 Manifold - Mikuni VM34
- Thank you received: 2098
the fuel level is within specs.
A specific dry measured float height is not the objective
The objective is achieving correct fuel level when the carbs are being supplied with fuel.
This is referred to as the "service" fuel level.
- treitz
Patton wrote: If not already done, would perform the clear tube test on each carb to assure that the fuel level is within specs.
The objective is correct fuel level when the carbs are being supplied with fuel.
I am using a PWK35 flat slide single carb. Unfortunately I cannot measure the float height with a clear tube because I do not have the necessary adapter.
- donthaveakawman
- Visitor
The special tool "adapter" isn't necessary.
Just use the bottom plug screw hole, same as clear tube testing smoothbores with the similar bottom plug.
Fashion a rubber plug/grommet arrangement whereby gasoline feeds into the clear tube through the bottom hole without excessive leakage.
A short section of oil line hose or a rubber grommet -- I use a cone shaped rubber grommet with a hole through it --with the clear tube snugly fitted inside.
Absent the actual true fuel level being within specs, further carb tuning efforts are futile.
- donthaveakawman
- Visitor
