'78 Kz1000, had to drill out stuck pilot air screw
  • Motor Head
  • Motor Head's Avatar
Re: '78 Kz1000, had to drill out stuck pilot air screw
24 Feb 2013 23:46
#573977
8x 1.5mm would be a Coarse thread. More like 8x 1.0mm or 8x .9mm would be a fine thread.
Got any pictures of how big the piece that is left looks like? I got one out by heating the body around the screw hole carefully with a small butane torch and soaking with PB Blaster. Took a while but it cam out. First drilling with a small drill, tried the left handed but it didn't do it. Then carefully using my smallest extractor. Pain In The A** for sure.
  • newOld_kz1000
  • newOld_kz1000's Avatar Topic Author
  • FlimFlamFlibbityFlee !! BoonFryedShickaMuhZee !!
25 Feb 2013 00:11
#573986
Motor Head wrote: 8x 1.5mm would be a Coarse thread. More like 8x 1.0mm or 8x .9mm would be a fine thread.
Good deal, I haven't ordered yet, I will order the 8mm x 1.0 then. The only one at the hardware store is 8mm x 1.25.
I have run through the easy-outs and drilling -- tried a small hole drilled and small easy out, nothing. Drilled a bigger hole, bigger easy out, nope. I'm out of brass now almost, there's enough material to drill then tap it.
It's all an experiment now, because the chance that the pilot air screw's function will be correct now is 'up in the air' so to speak -- I would need better tools and a bench press to correctly re-drill the pilot air screw hole and get it to match the factory hole there. But I'm anxious to try it.
My plan for this bike is to get it running first, get it road-worthy, then tear it down and repaint/etc. all the cosmetic stuff, and I'll probably have to swap in a new carb #2 carb body at that time, not sure yet.
My first task is to get it to start after sitting on the seller's back porch, close to the ocean, since 1984, 29 years of sitting. Big job here.
1978 kz1000 A2 with Kerker
1980 Z1 Classic with Kerker
25 Feb 2013 00:14 - 25 Feb 2013 00:21
#573988
Could try various size taps in a good pilot hole in one of the other carbs.
Of course, be gentle. The correct size tap will easily and readily screw into the hole, just like the pilot screw does.
A metric thread gauge is a handy inexpensive tool.
Good Fortune!:)
Last edit: 25 Feb 2013 00:21 by Patton.
  • wireman
  • wireman's Avatar
25 Feb 2013 00:15
#573989
Well I figured it was the finer of 2 options I had offered anyway! :woohoo:
Is it possible for the average shmo to even buy a tap that fine?
I can take an empty carb bodie to my tool/die guy tomorrow and ask him what the thread is and where to get one B)
  • Motor Head
25 Feb 2013 00:17 - 25 Feb 2013 01:16
#573991
If you can get one of the others out, then use a thread pitch gauge to find out what it is. Or maybe someone here can do that for you. Better to find out the size, then order the Tap. Ace Hardware has a good selection of Metric screws, taps and dies, etc. If you can get one out, they should be able to set you up with a Tap.
Did you spray in through the Air Horn/ Air Jet with penetrate? So the tip of the screw is soaked?
Last edit: 25 Feb 2013 01:16 by Motor Head.
  • newOld_kz1000
25 Feb 2013 01:34 - 25 Feb 2013 01:34
#574002
Motor Head wrote: If you can get one of the others out, then use a thread pitch gauge to find out what it is. Or maybe someone here can do that for you. Better to find out the size, then order the Tap. Ace Hardware has a good selection of Metric screws, taps and dies, etc. If you can get one out, they should be able to set you up with a Tap.
wireman thanks for your offer of help, patton I had never seen a thread pitch gauge I'll go buy one at Ace tomorrow:
Lordy I'm there man
driving to the big Ace Hardware near me, they have them online maybe in the store too
www.acehardware.com/product/index.jsp?pr...8450.2628076.2629205
That will without a doubt tell me which tap to buy, I'll bring a good pilot air screw with me tomorrow, measure it on the spot then buy the right tap.
MH I did spray into the pilot jet hole and the pilot air intake hole to soak the tip side of the stuck pilot air screw to no avail. It's probably a combination of the salty air, 29 years of sitting, and the oring around the inside of the pilot air screw creating friction
Last edit: 25 Feb 2013 01:34 by newOld_kz1000.
  • newOld_kz1000
25 Feb 2013 02:34
#574004
Okay I got real lucky, went to my tools, a metric tap/die set I had, what's left of it, had one of those thread gauge tools, the pilot screw threads are --
0.75
Sheesh. So here's my question, I took my caliper and read 6.92mm in approximate diameter of the pilot air jet's threads -- do I thus have
7mm x 0.75 pilot jet?
  • wireman
  • wireman's Avatar
25 Feb 2013 04:06
#574015
My tape measure doesn't have that small of lines on it! :woohoo:
  • Motor Head
25 Feb 2013 10:08 - 25 Feb 2013 10:25
#574030
Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 314. Please enable debug mode for more information.
  • turboking
  • turboking's Avatar
25 Feb 2013 10:59
#574040
MFolks wrote: www.kanolabs.com/ makers of "Kroil"
B) I'm still working on the gallon of kroil I bought years ago...... :blink: works wonders on stuck stuff
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
25 Feb 2013 12:37
#574051
newOld_kz1000 wrote: Okay I got real lucky, went to my tools, a metric tap/die set I had, what's left of it, had one of those thread gauge tools, the pilot screw threads are 0.75...caliper and read 6.92mm in approximate diameter of the pilot air jet's threads -- do I thus have 7mm x 0.75 pilot jet?
A cheap plastic size gauge should help. Available in several plastic and/or metal versions.
For instance, the screw may fit inside the 7mm hole but not the 6mm hole.
Good Fortune! :)
  • newOld_kz1000
25 Feb 2013 12:45 - 25 Feb 2013 12:46
#574052
I used this thread gauge to make sure I was using it and reading it right, each gauge blade has little teeth that fit into the threads. I figure that the gauge blade has to fit all the way down the length of the screw's threads, and not just a fit into a couple of the threads. That's my take on it.
The .7 gauge teeth fit mostly except at the edge (the pilot air screw on these 28mm carbs do NOT have many threads at all), and the .8 gauge only fits 1 or 2 threads then the rest fall outside the threads.
The .75 gauge's teeth all fit into the threads for the length of the pilot air screw.
Patton I will try to find one of those templates today it looks handy.
Jeff Bezos over at Amazon.com is getting paid today yet again from my fixit exploits:
www.amazon.com/s/ref=nb_sb_noss?url=sear...2Ck%3A7mm+x+0.75+tap
Dang they have a lot of stuff at Amazon.
Last edit: 25 Feb 2013 12:46 by newOld_kz1000.
