help!!! fuel hose dimensions/petcock on 82 650csr
- jbalet666
24 Feb 2013 23:19 #573968
by jbalet666
Hmm didn't think about the clearance issue well I'll take some measurements and contimplate if I want to do the work hahahaha thanks for the help as always
81 650csr
AoA
old soul young blood
Replied by jbalet666 on topic help!!! fuel hose dimensions/petcock on 82 650csr
martin_csr wrote: It would be easier & cheaper to get one in the KZR link I provided, as they are direct bolt-on.
For the one you linked you'll need an adapter plate kit & the tank bung hole will have to be reamed about ~2-4mm. Also, not sure, but you'll have to check the carb top clearance.
81 650csr
AoA
- Hollywoodmx
- Thank you received: 16
26 Aug 2013 21:00 #603221
by Hollywoodmx
The fuel line is 5/16 on the 82 gpz. Have fun with anything smaller.
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Replied by Hollywoodmx on topic help!!! fuel hose dimensions/petcock on 82 650csr
martin_csr wrote: The 650-CSR uses 5/16" fuel line & 1/4" vacuum line.
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- Beaner242
27 Aug 2013 01:14 #603275
by Beaner242
1982 KZ1000K LTD Chopper
Replied by Beaner242 on topic help!!! fuel hose dimensions/petcock on 82 650csr
I just had to take my peacock out tonight because I switched tanks. Mine is almost identical to the DCC one you linked to. Apparently the PO had changed it at some point so I already have the adapter plate that Martin spoke of. Also as he said you will have to open the hole in your tank just a bit to get the screen filter into the opening. I just used a drill and run the bit on the side of the opening until it fit in the hole. I have plenty of clearance between it and my carb but I don't know if our motors differ that much.
- jbalet666
27 Aug 2013 04:16 #603292
by jbalet666
81 650csr
AoA
yeah i installed mine as well works perfect i used a step drill bit (which was probably way more difficult than your approach) and its awesome but damn that sucker is heavy hahah
81 650csr
AoA
