- Thank you received: 391
Are these the right main jets for the BS 34?
- Motor Head
20 Feb 2013 23:09 #573389
by Motor Head
Replied by Motor Head on topic Are these the right main jets for the BS 34?
What size do you need?
www.z1enterprises.com/ListItems.aspx?keywords=jet+mikuni
- badrhino
- Thank you received: 6
21 Feb 2013 01:34 - 21 Feb 2013 01:39 #573413
by badrhino
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
Replied by badrhino on topic Are these the right main jets for the BS 34?
I got 137.5 to start. The tip of the new jets are smaller than the originals. See my picture above I have an original (122.5) sitting on the bag of new ones that are 137.5
Does that make a difference, maybe it's a newer design?
Franken Z!
Last edit: 21 Feb 2013 01:39 by badrhino.
- badrhino
22 Feb 2013 03:21 - 22 Feb 2013 03:29 #573546
by badrhino
Franken Z!
I seen Z1 has the large round ones and cheap until you go to check out and it cost over $7 to ship.
Franken Z!
Last edit: 22 Feb 2013 03:29 by badrhino.
- Motor Head
22 Feb 2013 10:10 #573559
by Motor Head
This is true if you buy just the jets you find them cheaper. But if you need a couple of other things, that are small/ light, shipping will probably still be the same. So then it is cheap. Maybe get a spare oil filter or two, or something like that.
- badrhino
22 Feb 2013 15:14 #573588
by badrhino
Franken Z!
Yeah I seen that when I was messing around with other stuff in the cart. I will probably make a list and order multiple items. Thanks
Franken Z!
