- Thank you received: 6
Are these the right main jets for the BS 34?
- badrhino
Here is the link:
These seem to be a lot smaller than the originals on the carbs. The threads look the same but the body is way smaller. Is this how they come now?
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
- badrhino
Franken Z!
- turboking
- Thank you received: 106
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
- turboking
1985 GS 1150E
1983 GS 1100E
- badrhino
Franken Z!
- Motor Head
- Thank you received: 391
- Thank you received: 2098
- badrhino
Franken Z!
- turboking
1985 GS 1150E
1983 GS 1100E
- turboking
1985 GS 1150E
1983 GS 1100E
- Rickman
BS34 main jets? Z1enterprises, or MikesXS.badrhino wrote: Where can one find the large round jets?
Speaking of BS34 parts at Mike's, these rubber pilot jet passage plugs are nifty: www.mikesxs.net/product/48-5002.html lots easier than the metal+o-ring plug that came in my rebuild kit.
1983 KZ1100-L1 "LTD Shaft"
Wiseco 10.5:1 1171 piston kit, bored by APE
Dyna 2000, Dyna S, Dyna grey coils, WG coil power mod, CB900 starter
- badrhino
turboking wrote: check this out......HTH these are for bs series
That part number is the same part number on the jets that I received. KN102.221 137.5
They are quite a bit smaller than the original. Just wondering if anyone else replaced theirs and got these.
Franken Z!
