- Thank you received: 3
Erratic idle on KZ1000
- 3cav84a
the bike is fitted with pods and a 4-1 V&H. The main jets are 120, pilots are 17.5 and the needle has been raised one position. I have recently had the cylinders honed and new rings fitted and an O ring set fitted to the carbs. Yesterday I pulled the carbs and found 3 of the pilot jets blocked, I recently put some fuel system cleaner in the tank, both fuel lines from the tank have in line filters.
I did the valve clearances last week and all are within spec. The timing is correct, (it is a Dyno III system with Dyno coils.
Having done a search on the forum for these symptoms it is pointing to an air leak somewhere. I sprayed the rubber manifolds and carbs with RP7 while it was running but did not pick up any change in running, any ideas of what I should be looking at next, regards Neil
1977 KZ 1000 A1
- baldy110
- Thank you received: 512
- 3cav84a
1977 KZ 1000 A1
- newOld_kz1000
- FlimFlamFlibbityFlee !! BoonFryedShickaMuhZee !!
- Thank you received: 20
3cav84a wrote: This came on all of a sudden, I did the advance mechanism when I adjusted the shims for the valve gap about a week ago. My timing light had blown a globe so I set the timing with the static method. Thanks for the suggestions, this is realy getting to me as the weather is absolutely perfect for a ride, the bikes will be out in full force today, regards Neil
I have been told that exact symptom -- 'funky idle' can be caused by one or more missing part #32 in this diagram -- it's a rubber o-ring that slips onto the pilot adjustment screw (part #31 is the pilot adjustment screw):
The symptoms I was told were: "sometimes the idle seems fine, other times it's erratic, it will rev high, or it won't idle at all" sounds like what you have.
Me personally? I used to think "the dang orings there are so tiny, if I lose one or all of them big deal, surely they're 100% unimportant, they're too small to be needed. "
So luckily I've always been careful during carb cleans/rebuilds to honor the parts diagram and adhere to it, mainly because I'm an anal sumbidge. So I've never had a need to troubleshoot this problem as being due to missing or old/damaged pilot o-rings.
But seeing as how you have the idle symptoms he spoke of, a question for you is, that diagram above is for the 1977 Kz1000-A model, do you have those carbs and/or does the carb set you have need those rubber orings on the pilot screw there?
1978 kz1000 A2 with Kerker
1980 Z1 Classic with Kerker
- 3cav84a
1977 KZ 1000 A1
- Thank you received: 2098
- 3cav84a
Attachment IMG_0517.JPG not found
1977 KZ 1000 A1
Attachment picpostnewsite912x671.jpg not found
What browser is being used?
If using latest version of Firefox, could try a different browser.
Lastest versions of Firefox were recently unable to post pics, but I don't know whether the issue has yet been resolved.
Note also the side-located float bowl drain screw.
And the overflow nipple from bottom of float bowl.
- newOld_kz1000
3cav84a wrote: The bike is a 77 KZ1000, year of manufacture is 12/76 but the carbs are not as you pictured, mine have an air screw coming in from the side on the air cleaner side of the carb. I just took it for a ride and it is just as erratic. I think I might try taking the air screws out to about 2 1/2 turns and maybe drop the needle back to it's original position.
Another easy check. On the intake manifolds (the black rubber parts that connect the front of the carb to the engine) there should be a capped-off vent on each manifold, as shown here:
THIS IS A PICTURE OF A SET OF 4 Kz1000 INTAKE MANIFOLDS:
If you notice, there are plugged-off ports that stick out from each rubber manifold. In the photo, those ports are capped by rubber covers that look like a big rubber bullet.
An easy thing to check -- make sure
1) each of your intake manifolds has a port that is capped because otherwise air will get sucked into the engine on that cylinder, wreaking havoc with the RPMs of that cylinder
2) now, after verifying all four intake manifolds are properly capped off -- CHECK THE CONDITION OF THE CAPS. If they're dilapidated and not capping the port off completely, air will get sucked into that port, messing with the running of that cylinder.
Those capped-off ports are used to adjust the carbs -- unless you're doing a carb adjustment, those ports sticking outward from each manifold *must* be capped off and closed.
If one of those ports is open, it will 100% screw up the idle and the affected cylinder can race up in RPMs due to the air leak at that port.
- 3cav84a
Patton yes I am using the latest version of Firefox so I will try another one regards Neil
1977 KZ 1000 A1
- 3cav84a
1977 KZ 1000 A1
