Erratic idle on KZ1000
- newOld_kz1000
- FlimFlamFlibbityFlee !! BoonFryedShickaMuhZee !!
Re: Erratic idle on KZ1000
17 Feb 2013 08:16 - 17 Feb 2013 08:163cav84a wrote: So I finally was able to upload a picture of the carb,I pulled them out again and lowered the float level on each of them, same result. It is now showing a pattern whereas when I start it the bike will idle on about 1000 rpm and sit there all day so long as I don't touch the throttle but as soon as I wind up the rpm it will sit an about 2500-3000 rpm until I turn the ignition off. I think I will have to swallow my pride and take it to a bike mechanic as it has totally beat me. 5 days working on it and no results, I have better things to do.
You have (may have) an air leak. However, first, a couple other things that can create high idle is
- the choke is on -- turn your choke on and off while watching the 4 carbs so you can discover the part on each carb that moves when the choke is turned on and off. Then make sure that when you turn the choke off, each carb's choke does in fact close, ie. you don't have one carb's choke sticking on
- the large round idle adjustment screw knob needs to be adjusted -- you owe it to yourself to at least try that one -- find out where that big round idle adjustment knob is on your set of carbs and when the bike does rev up to 2500-3000, try lowering the idle by turning that idle adjustment knob. Sometimes when we rebuild carbs that large round idle adjust wheel gets bumped and raises the idle.
One of the main symptoms of an air leak is an idle that will not settle down.
Could be:
1) one of those rubber plugs on one of the intake manifolds (see my earlier post with photo of the 4 carb intakes) -- one of the rubber plugs is missing or cracked/broken allowing air to get in at that point -- that cannot be allowed, that port is for hooking up a carb adjustment meter
2) a cracked, old and dried-out intake manifold -- if you pull the carbs and then remove the intake manifolds you can check for cracks/leaks -- if the manifolds are old and hard, they might leak
An air leak has as a symptom an idle that will not 'settle down.'
1978 kz1000 A2 with Kerker
1980 Z1 Classic with Kerker
Last edit: 17 Feb 2013 08:16 by newOld_kz1000.
- turboking
17 Feb 2013 10:09
probably an air leak ,but....... :ohmy: just to throw this out there. :blink: idle speed knob adjusted correctly.
Check throttle cables as they need slack to work properly. :huh: are they too tight since you removed and reinstalled the carbs? :blush: it's supposed to have 2 to 3 mm throttle grip play. hth
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
17 Feb 2013 10:14 - 17 Feb 2013 10:17During the racing idle, could try pushing the throttle closed by hand at the carb end, to see whether or not racing idle persists.3cav84a wrote: ... when I start it the bike will idle on about 1000 rpm and sit there all day so long as I don't touch the throttle but as soon as I wind up the rpm it will sit an about 2500-3000 rpm until I turn the ignition off....
Could disconnect throttle cables at carb end -- needle-nose pliers may prove helpful -- then increase throttle manually by hand, with throttle cables disconnected, allowing the carb spring to pull the throttle closed (free of any resistance involving throttle cables) .
Either test could help diagnose whether or not a maladjusted or hanging throttle cable is causing the racing idle.
Last edit: 17 Feb 2013 10:17 by Patton.
- 3cav84a
18 Feb 2013 06:17
So today I ran the bike with the throttle cables disconnected, for the same result. I pulled the rubber manifolds off for a thorough inspection, they appear OK with no cracks, I have ordered a new set so that I can cut them out of the equation.
There is now a distinct pattern of clues developed.
Here is a rundown:
Start bike from cold needs choke
Bike is soon able to go off choke with the idle rpm at about 1000 rpm.
let bike warm up 3-4 minutes still at around 1000 rpm.
operate throttle so bike goes to 2000-2500 rpm and bike will hang there until I switch it off at ignition.
Immediately start bike and it is back to normal idle. The more I think about it I think the problem is not carbs or air getting in. I am thinking the springs on the centrifugal advance mechanism have weakened, all of the above clues tell me the advance mechanism is staying in the advanced position even though I have shut the throttle off.
I don't know if you can just buy the springs or if you have to buy the whole mechanism but I am really hoping that this might be the cure, if not you may send cards and letters to me Neil Holbrook care of the Adelaide Institute for the mentally insane LOL :woohoo:
Here is a rundown:
1977 KZ 1000 A1
18 Feb 2013 07:54 - 18 Feb 2013 09:26Pivot points may be lubed by access through the timing window. But may do a more thorough inspection and servicing (clean and lube) by removing the advancer.
Last edit: 18 Feb 2013 09:26 by Patton.
- peter1958
- Banned
18 Feb 2013 09:09
if the rubber is bad on the choke plungers it can cause the same thing.
www.kzzone.com/
- 3cav84a
18 Feb 2013 23:05
G'day, I finally got a result, nothing wrong with the carbs although after all the stripping and cleaning I can do it in my sleep with my eyes closed.
Today I worked on my theory about the centrifugal advance mechanism hanging in the advanced position due to weak springs. I removed the springs and squeezed them together in a vice and got them red hot in a gas flame, I let them cool naturally without putting them in water replaced the springs and the bike has been running as it should do. I would suggest that eventually the springs will go weak again but by that time I should have a new advance mechanism installed.
Thanks to all who contributed suggestions as a result I am getting new inlet manifolds with new clamps.
I know that this was a strange one with all the indicators leading to an air leak but it was not until I really studied the symptoms that I decided to look at the springs, apparently a rare condition but it goes to prove you can't disregard anything, cheers Neil
1977 KZ 1000 A1
The following user(s) said Thank You: kingn8dogg
- Rowdymk2
19 Feb 2013 04:24
Sounds to me like you have an intake leak I had that problem and it was because the silicone I used was permiable to gas . The best thing I found is 3m weather strip silicone if you take the boots off apply a bead of it and allow it to set up the apply another bead before installation and let it set a few hours best over nite it works greats I had that problem with an on Yamaha I had . Give it a try and best of luck
